Custom Header Thread
+14
whitefield
gmsmkr
70FB
514F-1
yellowhorse7
GTmustang
18 posters
Custom Header Thread Empty Custom Header Thread
Post  whatbumper February 8th 2015, 5:13 pm
Post up some work.  Trying to brag a little but it helps to see whats out there for ideas.
X275 car.  I know it's a bbc but the idea is the same.  Hard to package 2.5" nitrous headers in a stock framed chassis.
Custom Header Thread 20150213
Custom Header Thread 20150211
Custom Header Thread 20150212
Custom Header Thread Img_4110
Custom Header Thread Img_4111
Custom Header Thread Empty Re: Custom Header Thread
Post  69F100 February 8th 2015, 5:52 pm
Here is the ones I built for mine 2 1/4'' tubes after I put the strut frontend under it would have been a lot harder with the stock front
Custom Header Thread 0903141711_zpsvzzkvvym
Custom Header Thread 0901141949_zpsxcqnn4ox
Custom Header Thread 0903141711b_zpscmvv1spc
Custom Header Thread 0903141711a_zpsdxbijr3z
Post  whatbumper February 8th 2015, 7:21 pm
looks good.  It is easier when you have room.
Here's another.
Custom Header Thread 10415510
Custom Header Thread 10440610
Custom Header Thread 10453410
Post  69F100 February 8th 2015, 8:43 pm
Here a couple more of the header I built with the stock front that exited under the truck when I 1st built it
Custom Header Thread 10-31-09011
Custom Header Thread 10-31-09010
Custom Header Thread 10-31-09008
Custom Header Thread RANGERCAGE010-1
Post  windsor February 8th 2015, 9:27 pm
I think I'm gonna like this thread. Keep em coming folks.
Post  cool40 February 8th 2015, 11:45 pm
706 BBC in a fox body...    Custom Header Thread 20131108_174030
Post  whatbumper February 9th 2015, 10:50 am
X275 Nova 2.5" primaries. These were mild steel as customer was getting them jet-hot coated. Notice how easy plug maintenance is.
Custom Header Thread 10401910
Custom Header Thread 10527410
Post  rmcomprandy February 9th 2015, 11:02 am
A lot of people in that situation go to a Tri-Y design simply because they take-up a lot less space when going big.
I have no idea whether or not they work better or worse or the same in those nitrous situations.
Post  whatbumper February 9th 2015, 11:20 am
rmcomprandy wrote:A lot of people in that situation go to a Tri-Y design simply because they take-up a lot less space when going big.
I have seen that. We have actually not done any dyno testing to compare but that would help with packaging if the power was close.
Post  John Myrick February 9th 2015, 11:33 am
What's a ballpark price for a set of custom mild steel headers ?
Post  GTmustang February 9th 2015, 11:55 am
These are my custom 2- 2.125" step BBF Fox body headers that were built by Tom Stiel of Waterford MI for my 1992 GT w/ a 1.5" engine drop and 1.5" setback. Tube size and primary length were spec'd by the engine builder, Rand Malik (rmcomprandy) of Roseville MI.
[img]Custom Header Thread IMG00336-20130711-2015[/img]
[img]Custom Header Thread IMG00335-20130711-2015[/img]
The headers were ceramic coated by QC Coatings of Roseville MI for a little underhood heat reduction and a lot of Bling!
[img]Custom Header Thread RogersCity-20140218-00142[/img]
The individual header tubes and bolt on collectors make installation a little easier, but it is a real puzzle anyway with the tubes snaking through a fairly tight space!
Gary
GTmustang
Post  yellowhorse7 February 9th 2015, 12:12 pm
Let's take it 1 step further and talk about designing a MAX EFFORT header. N20, N/A, Turbo, whatever.
Merge Collectors, Stepped or no, tube size, equal length or no??????
So many opinions out there on this subject.....what's yours? study
yellowhorse7
yellowhorse7
Post  whatbumper February 9th 2015, 12:59 pm
John Myrick wrote:What's a ballpark price for a set of custom mild steel headers ?
There are some people that knock them out for about $1000 but we charge more.  Most of our big tube nitrous style stuff is in the $2000 range including mufflers built on the car including moving items and clearance stuff as needed unless it is major firewall work and then it goes up.  Coating is extra.  Like I've said in another thread cheap is in the eye of the beholder.  We could throw a set of tubes together in a few hours if you aren't worried about plug maintenance or if the tires hit.
To be honest we build 9 set of stainless for ever set of mild because of the price difference after coating, resell value on car, and overall life.
The set on the gold nova above actually weighed 12 lbs less than a set of hookers that were on the car and the engine tuneup changed dramatically.
Post  whatbumper February 9th 2015, 1:08 pm
yellowhorse7 wrote:Let's take it 1 step further and talk about designing a MAX EFFORT header. N20, N/A, Turbo, whatever.
We've done a little of it all.  Tube size for nitrous is "big".  Don't see a real big difference on stepped stuff in the cars we do.  We honestly aren't that concerned with equal length of tubes unless it's NA as we don't see much difference in data on nitrous cars but everyone has different data so I'm sure someone can counter that.
turbo on the other hand:  we shoot for more equal and try to keep everything tight to each other to hold heat.  primary size is based on cubic inch of motor and not necessarily power output.  we use double slip collectors on turbo stuff unless it is retrofitting an old set of headers like these below.
 Custom Header Thread 13920110
at that time we are more concerned with wastegate placement.
Custom Header Thread 13920810
Post  res0rli9 February 9th 2015, 1:45 pm
X2
Post  richter69 February 9th 2015, 2:19 pm
ive done like 4 sets and fixin to do another real soon.
x2 on the heavy nos stuff just make um big and let the stuff get out of um asap.
Post  514F-1 February 9th 2015, 5:54 pm
Good work guys, having a set of side exits done for my truck now, they just sent me the completed pics, but they are on my phone, i'll get some when they get back from the powdercoater. They look badass even before the ceramic coating. Cool
514F-1
514F-1
Post  70FB February 9th 2015, 7:57 pm
Suscribed
70FB
70FB
Post  gmsmkr February 9th 2015, 8:01 pm
There is some nice work on this post I have not built any yet but will give it a go soon...keep the pics coming
gmsmkr
gmsmkr
Post  whitefield February 9th 2015, 8:08 pm
study Cool
whitefield
whitefield
Post  cool40 February 9th 2015, 10:00 pm
Custom Header Thread Drysump006 2.5" easy to build chassis headers. clown
Post  whatbumper February 9th 2015, 11:18 pm
cool40 wrote:Custom Header Thread Drysump006 2.5" easy to build chassis headers. clown
Look at all that space. Lol
Look good.
Post  David Cole February 10th 2015, 7:02 am
Mine are not equal length, but it doesn't seem to hurt it.
Custom Header Thread HeaderR
Custom Header Thread Wires1
Post  whatbumper February 10th 2015, 11:19 am
Custom Header Thread 15008110
Custom Header Thread 10697310
Custom Header Thread 10406810
Custom Header Thread 10551410
Post  whatbumper February 10th 2015, 11:21 am
We back purge all tubing welding and build our own collectors and mufflers unless customer provided.  We TIG weld everything we do including body modifications we do to limit weld splatter on the car.
We agree with Jon above above nitrous header size. Big and get rid of it quick. The stainless is nice because after a pass you can take the hood off and usually it is cool enough to take plugs out immediately.
