timing chain for aligned bore blocks?
timing chain for aligned bore blocks? Empty timing chain for aligned bore blocks?
Post  powerstrokeace February 10th 2015, 10:59 pm
I have a block that was aligned bored and the chain that came off was pretty loose not very many runs. So i thought i would replace it with a -.005 smaller one. questing is? where do the make the -.005 adjustemnt? in the gears? and if so which one or both
Ace
powerstrokeace
powerstrokeace
timing chain for aligned bore blocks? Empty Re: timing chain for aligned bore blocks?
Post  10.0 February 11th 2015, 6:07 am
Yeah, the gears are machined slightly larger.
I think i have an extra set up in the shop if you need one.
10.0
Post  Doug Rahn February 11th 2015, 8:39 am
Cloyes has the chain and sprocket sets in just about all of their series that are available in .005 and .010 shorter sets.
Post  rmk57 February 11th 2015, 10:37 am
I thought the gear teeth weren't machined as deep, making the chain sit higher.
rmk57
