Rpm doing a burn out
+13
butterbean
gt350hr
gmsmkr
tconnection
17 posters
Rpm doing a burn out Empty Rpm doing a burn out
Post  tconnection March 31st 2015, 11:40 pm
What rpm are u guys at during a burn out?
tconnection
Rpm doing a burn out Empty Re: Rpm doing a burn out
Post  gmsmkr April 1st 2015, 12:33 am
There is no magic rpm stop the burnout when motor lugs down.
What trans are you using?
gmsmkr
gmsmkr
Post  Frank Merkl April 1st 2015, 12:42 am
we like  7800-8300 rpm
https://youtu.be/Xi727cJZuh0
Post  bruno April 1st 2015, 6:38 am
My old deal was around 6800-7000
http://WWW.CKRME.COM
Post  dfree383 April 1st 2015, 6:58 am
5500-6000 is plenty IMO no need to rev the shit out of it.
With my door car I start in 1st shift to 2nd and let it roll out after a few seconds and ease out if it.....
Dragster, roll 2nd thru the water and nail it.
Post  Curt April 1st 2015, 8:57 am
2nd gear at 7000rpm. Just long enough to clean the tires. I'm one of the few dragsters that don't burn out across the starting line.
Post  tconnection April 1st 2015, 10:06 am
C6, 29.5 tire, 430 gear.
tconnection
Post  gmsmkr April 1st 2015, 10:19 am
Imo.. with that trans tire and gear I would start the burn out in 1st gear run it up to 5500 shift to 2nd and let it roll out you will know when it sticks
gmsmkr
gmsmkr
Post  bbf-falcon April 1st 2015, 10:20 am
Never was a high speed burnout fan.After the shift and the tires start to pull,ease out of throttle.Just do it same each time IMO.
Post  gt350hr April 1st 2015, 10:32 am
6,000 rpm high gear max.
gt350hr
Post  IDT-572 April 1st 2015, 11:15 am
X2 Roll through the water box and a good 3 foot up onto the dry and blip the throttle in high gear and bring it up to 6000 rpm for about a 3 count, cold weather a little longer hot weather a little less.
Post  Dave De April 1st 2015, 6:53 pm
With a c6 start the burn out in second gear. No need to put it to the floor but opening the back barrels a little is a good idea. Shift into high before the shift light is okay but as soon as you hit high gear start your internal count. Mine is one thousand one, one thousand two, one thousand three, then let go of the brake while reducing the throttle.
Like others have said make sure you are out of the water box wet zone. I rollout a foot further than the when the starter gives me the fist to stop. Everyone has their own twist on their routine, you need to find your own.
Post  69F100 April 1st 2015, 7:33 pm
gmsmkr wrote:Imo.. with that trans tire and gear I would start the burn out in 1st gear run it up to 5500 shift to 2nd and let it roll out you will know when it sticks
This is the way I did with my c6 to me the John Force burn outs are a waste of good rubber and I am one that can't afford to buy new tires every time I go to the track.
Post  FalconEh April 1st 2015, 8:52 pm
Chirp, and yank... the tires are ready, I find all tires are different, new slicks heat easier than older ones, street slicks (less heat) are different than slicks, as for RPM whatever you are comfortable with...ie: you can heat for longer at a lower RPM and still achieve the temp they like IMO you cannot take all day and it has to be repeatable, so mashing the throttle to an RPM is different than leaning into the throttle to an RPM, consistency is the objective, try different things until they work like you want and temps ( tire and motor) are where you want and make sure it is repeatable.
Post  gmsmkr April 1st 2015, 9:37 pm
How ever you do it you do not make a test hit..... The best hit you get is after the burn out I see lots of guys do this and the test hit works great and then they wonder why it didn't grab at the light Rolling Eyes
gmsmkr
gmsmkr
Post  butterbean April 2nd 2015, 9:33 am
(test hit?) do you mean dry hop??
butterbean
butterbean
Post  gmsmkr April 2nd 2015, 10:27 am
butterbean wrote:(test hit?) do you mean dry hop??
Yes
gmsmkr
gmsmkr
Post  dfree383 April 2nd 2015, 10:29 am
I just got the mental picture of a 1970's prostock match race..... cheers
Post  gmsmkr April 2nd 2015, 10:33 am
cheers ol done nickolson Mavrick come to my head now...
gmsmkr
gmsmkr
Post  bbf-falcon April 2nd 2015, 12:44 pm
Seems like everyone thought they had too do that in the 70's Rolling Eyes Including me Embarassed
Post  Curt April 2nd 2015, 12:56 pm
gmsmkr wrote:How ever you do it you do not make a test hit.....
^^^^ Convertor Murderers^^^^
Post  514F-1 April 2nd 2015, 1:53 pm
I bring it up to about 6 Quick, shift to second (powerglide) and the let off the line loc and ride it out a little waysways. I keep the RPM under 6800.
514F-1
514F-1
Post  maverick April 2nd 2015, 10:01 pm
I don't shift during a burnout. I watched a friend break a pinion shaft right at the shift in the burnout...apparently, when the rear axle made that little "hop" at the shift, well...it tore up a bunch of stuff. Anyway, I figure an all high gear burnout is generally easier on parts. And if a race car can't spin a wet slick in high gear, well...... Rolling Eyes
Anyway, my best advice is DO NOT spin the tires in the puddle. I know, I know, they're trying to wet the tire all the way around, as if it matters. What they're really doing is throwing water up into the wheelwells so that it can drip out at the starting line. These same guys might occasionally wonder why their 60' times are a little inconsistent.
Aside from that, easing out of the throttle before the final hook is mandatory, as said above. And most tire manufacturers will tell you that their tires don't require long smoky burnouts anymore. Just getting them clean and dry is usually enough. Tire tech has evolved, too. That's good news to me because I hate trying to see the tree clearly with a car full of smoke.
Post  Dave De April 3rd 2015, 12:14 pm
Maverick are you still in Michigan or are you living in Bama?
I like your recommendation to just use high gear. I'm going to try that and see how it works.
Post  maverick April 3rd 2015, 12:31 pm
Dave De wrote:Maverick are you still in Michigan or are you living in Bama?
I'm in 'Bama. Grew up in Bay City....haven't lived there since '85. Got lotsa friends up there, tho. Spent 23 years in Florida, the last 7 1/2 years here.
I've always used high gear only. No need to flog the trans and rear end, and the tire comes up to speed quickly....I just tap the throttle up to 6000, count one, two, three and let it roll out while lifting off the gas. If I get just a wisp of smoke it's enough. I've never seen any real difference in my short times, trying longer and shorter burnouts, but then again, this car will hook on wet grass. So since I'm the guy buying the tires...shorter is gooder. Rolling Eyes
