Innovators balancer marks
Do all the Innovator balancers only have marks at 0,30,40 and 50? Seems rather cheap for how much they cost.
jasonf- BBF CONTRIBUTOR
Re: Innovators balancer marks
Its not difficult to understand each big mark is 10 degrees..... But you are right a lot of the general population isn't smart enough to catch on to this.....
Once you figure out where it should be, there should be a permanent mark anyway. If you're smart enough to time it, you're smart enough to know where you are on the balancer.
Curt- Posts : 2791
Well I usually put a permanent mark on there and I can count to 10 but that is not the point. Why go to all the trouble to scribe it all the way around then not put markings on it? Half assed is what it is.
Are you referring to it not having 10 & 20 marks?
» timing marks
» timing pointer/ balancer marks.
» Crankshaft manufacturer marks, What tells you what you have?
» ***** innovators west ******
» Innovators West Dampners
