What pan is this?
What pan is this? Empty What pan is this?
Post  75truck April 7th 2015, 11:12 pm
Here is the pan - is it from a marine / jet boat and can I run it on a 429 in my 75 Ford truck?  Looks like it is designed to keep the oil in the front of the pan under acceleration.
What pan is this? Pan
Bob
Tucson
75truck
What pan is this? Empty Re: What pan is this?
Post  cool40 April 7th 2015, 11:21 pm
Factory cj, cop car pan looks like. Suspect
Post  supervel45 April 7th 2015, 11:46 pm
If it's the same dept as a front sump passenger car pan the sump will be right on the crossmember. If the oil drain plug is on the side you won't be able to remove it. You can put a weld in drain plug in the front bottom of the sump.
What pan is this? Empty Weld in oil drain?
Post  75truck April 8th 2015, 1:01 am
Where do you get on of those weld in ones?
Bob
Tucson
75truck
Post  supervel45 April 8th 2015, 1:12 am
http://www.oreillyauto.com/site/c/detail/BM00/80250/N0616.oap?ck=Search_N0616_1095904_-1&pt=N0616&ppt=C0377 I used one of these and left the back nut and nylon washer off, and welded it on. Check it for leaks before you put it on the engine. The front sump pans are a tight fit in a F150, and you will have to pull the engine if you need to take it off for any reason. You might consider looking for a rear sump truck pan.
What pan is this? Empty I might have something
Post  manofmerc April 8th 2015, 6:47 am
I have an oil pan off a mid 70s 460 powered pickup .It is a front sump and it is big probably holds 7-8 quarts of oil ,I don't have the oil pump pickup though .If interested give me a call 678 603 8400 Doug
manofmerc
What pan is this? Empty Brazed in the oil pump bung.
Post  75truck April 8th 2015, 11:06 am
I have taken one of the metal add-on drains and just brazed it in.  You have to clean the metal really well.
I did not like the nylon seals that come with them.
Bob
75truck
Post  gt350hr April 8th 2015, 12:43 pm
manofmerc wrote:I have an oil pan off a mid 70s 460 powered pickup .It is a front sump and it is big probably holds 7-8 quarts of oil ,I don't have the oil pump pickup though .If interested give me a call 678 603 8400 Doug
The truck pan actually holds more oil as the sump is bigger. I made my own baffle ( copied the one shown in the picture) and added it to the big truck pan. Best of both worlds.
gt350hr
