P-51 heads
+17
butterbean
Gary Blair
wayney
quick 52
JACKAZZFLATZ
8liter
glenevans
21 posters
Page 1 of 4
Page 1 of 4 • 1, 2, 3, 4
P-51 heads
I just mounted a set with Kaase hardware and it was plug and play. No cutting guides, bending and welding. I didnt even need to push the guides around to get the geometry straight. After the issues with SCJ's this was a surprise.
If this is normal and you are considering SCJ's save yourself the extra four hours altering the guides and just buy the P-51s.
Now we'll see how much it picks up.
Dave De- Posts : 797
Re: P-51 heads
Dave De wrote:I just mounted a set with Kaase hardware and it was plug and play. No cutting guides, bending and welding. I didnt even need to push the guides around to get the geometry straight. After the issues with SCJ's this was a surprise.
So when are you planning on hammering down on the loud pedal, for the comparison?
FalconEh- Posts : 1448
Re: P-51 heads
Should be testing at Milan next Saturday. Im street legal so I will do a little testing on the street even though its not very good.
Cant go wot on the street.
Re: P-51 heads
Nice, My street strip s#{t runs a go cart tire and trying to go WOT with a frosted SB is reminiscent of John F and Tony P for the title, hooks on the track though, we will see when the BBF is installed
Anxious to see how the new P51's work out
Re: P-51 heads
That sounds good, I have a set of P-51 heads to install soon, never had any aftermarket heads before these.
glenevans- Posts : 315
Re: P-51 heads
you have to flycut the pistons?
8liter- Posts : 202
Re: P-51 heads
8liter wrote:you have to flycut the pistons?
If you are running OEM style pistons the will need a p51 relief cut, if your are buying pistons make sure to get the p51/SCJ reliefs
Re: P-51 heads
I'm sure it'll fly. If I remember right, the P-51's came out a week after I bought the SCJ's.........naturally.
JACKAZZFLATZ- Posts : 249
Re: P-51 heads
Bada Bing Bada Boom should fly nice work DaveDave De wrote:Should be testing at Milan next Saturday. Im street legal so I will do a little testing on the street even though its not very good.
quick 52- Posts : 612
Re: P-51 heads
Dave are you dragging it to BC then heading out... Should have the old farm truck ready in a few weeks...
Re: P-51 heads
I will be loading up after BC and heading to the track.
Re: P-51 heads
I finally have a P-51 comparison to my previous SCJ-b heads. It has been a difficult season where the first time out I blew the drive shaft slip yoke and destroyed the tail shaft, bent the main shaft and trashed the case on the C6. In any case the car has picked up less than a 1/10 where it would go 9.32 average to now 9.24 with a best today at 9.20 and 145.6 mph. I might get a few 1/100s with some more tuning. I was thinking there would be more change. The mph only went up 1mph. Shifting at 6300 gives the best et.
Stats
580 cubes, 13.4 comp, 3100 pound car, both heads were ported and the SCJ heads have 2.25 valves.
Im okay with the package because my SCJs will be used on a new 560 motor for my Torino to get it into the tens.
Stats
Re: P-51 heads
Dave De wrote:I finally have a P-51 comparison to my previous SCJ-b heads. It has been a difficult season where the first time out I blew the drive shaft slip yoke and destroyed the tail shaft, bent the main shaft and trashed the case on the C6. In any case the car has picked up less than a 1/10 where it would go 9.32 average to now 9.24 with a best today at 9.20 and 145.6 mph. I might get a few 1/100s with some more tuning. I was thinking there would be more change. The mph only went up 1mph. Shifting at 6300 gives the best et.
Stats
My neighbor had similar results with this swap.
cletus66- Posts : 865
Re: P-51 heads
Stats
both heads ported, to what extent ? what was the flow difference between the 2 heads?
wayney- Posts : 187
Re: P-51 heads
Stats
What this tells me is that there is something else in the package beside the heads which is holding this back.
Re: P-51 heads
rmcomprandy wrote:Dave De wrote:I finally have a P-51 comparison to my previous SCJ-b heads. It has been a difficult season where the first time out I blew the drive shaft slip yoke and destroyed the tail shaft, bent the main shaft and trashed the case on the C6. In any case the car has picked up less than a 1/10 where it would go 9.32 average to now 9.24 with a best today at 9.20 and 145.6 mph. I might get a few 1/100s with some more tuning. I was thinking there would be more change. The mph only went up 1mph. Shifting at 6300 gives the best et.
Stats
Good point.
Re: P-51 heads
The SCJs were to flow over 385 and the P-51s have data sheets that show 425. When I first ran the P-51s I used 1.8 rockers and the car slowed down a little or there was no change over the SCJs. I went back to 1.73 rockers and it picked up. This cam is intentionally compromised to be small for reliability. Could my full 4" exhaust with Flowmaster 44s be an issue? The mufflers have the second baffle knocked out.
I thought that with 580 cubes it would pick up more because these heads are ideally suited for less displacement. Then with 10 percent more flow it would like to run higher and it really doesnt. I think that if I were to have dyno'd each setup there wouldnt be much difference in power.
Well at least ive got the SCJs for the other motor now.
Re: P-51 heads
Your cam is probably not allowing you the advantage the p-51 head has to offer.
Re: P-51 heads
Same
Re: P-51 heads
A cam with less duration is required?
Re: P-51 heads
I'd ditch the Flowmisers for a "straight through" type...or use no muffler at all.
maverick- BBF CONTRIBUTOR
Re: P-51 heads
Dave De wrote:A cam with less duration is required?
Whats in it now? My bet its too small.
Re: P-51 heads
richter69 wrote:Dave De wrote:A cam with less duration is required?
You'd probably lose ... 278/290 @.050" is not what is holding it back from making power at 6,500 RPM; though something else might be.
Re: P-51 heads
mine was a hell of a lot bigger than that.........
...... and there may be other issues
also it aint like he went from a procomp
Comparison
Interesting comparison. You can compare flow curves, dyno tests etc., but there is nothing like an ET slip to see what if any you have gained or lost.
Gary Blair- Posts : 221
» Wanted..... Cast iron Blue thunder Ford port heads or CJ heads
» A429 Heads VS Dove-c Heads
Page 1 of 4
