Project -- zephyr
larry552
johndickjr
Project -- zephyr Empty Project -- zephyr
Post  johndickjr April 15th 2015, 4:00 pm
since my my falcon is at the weld shop getting a full cage and mini tubed and new frame rails , i bought a straight 1979 mercury z7 zephyr to play with , it had a 302 in it, i added some heads a cam , some gears and converter to quickly find the weak link , it broke a rod, so i decided to use the motor and tranny -converter i had built for the falcon and use it for the zephyr, the car is going to the weld shop tomorrow for a 8 point roll bar, the rear is a 8.8 with 3.73 gears, built c4 tranny with brake and a 4800 9inch converter, motor is a 393ci with heads that flowed 306 intake and 246 exhaust , the was 200cc runners before ported, cam is a comp solid roller .691-692 Duration@.050 intake 261 exhaust 268, ross pistons , -eagle h beam rods compression is almost 13-1, fully ported super vic intake
Project -- zephyr 0411151209a1_zpsewtjhxke
Project -- zephyr 11011417511_zps5jngxirt
johndickjr
Project -- zephyr Empty Re: Project -- zephyr
Post  larry552 April 15th 2015, 11:40 pm
It b should be a stout ride
larry552
larry552
Post  johndickjr April 16th 2015, 11:20 am
like to see 6.90-7.0
johndickjr
Post  maverick April 16th 2015, 4:27 pm
Should do it. A buddy's Fox Mustang hatch with a 408" Windsor (probably not as snotty as your 393) ran pretty consistant 6.60's. Great bracket car, too.
Post  johndickjr April 20th 2015, 10:46 am
better side view pic
Project -- zephyr Racecar_zpsuxg336nu
johndickjr
Post  dfree383 April 20th 2015, 11:39 am
Neat looking car
Post  61coon April 25th 2015, 10:16 pm
Don't see many of those old cars, cool ride!
61coon
61coon
Post  johndickjr May 1st 2015, 4:19 pm
got motor in, headers are on, what a pain in the ass,but was free
johndickjr
Post  gmsmkr May 1st 2015, 6:46 pm
Pics cyclops
gmsmkr
gmsmkr
Post  whitefield May 3rd 2015, 3:31 pm
^^^^ x2 you have anymore pics or update ?
whitefield
whitefield
Post  johndickjr May 3rd 2015, 5:44 pm
whitefield wrote:^^^^ x2  you have anymore pics or update ?
all bad, when i got this block and pistons rods..etc it was bored , new cam bearings ..etc..well i never checked the freeze plugs, i got motor in and put water in and it looked like ole faithful , all 6 of the plugs was rusted , my fault for not checking and catching it, so i had to pull the motor back out, just now got it back in, ill get some pic tomorrow
johndickjr
Post  gmsmkr May 3rd 2015, 10:34 pm
The problems we have as hot rodders Smile just makes it worth it more in the long run
gmsmkr
gmsmkr
Post  johndickjr May 4th 2015, 5:13 pm
fuel system is 1/2 inch stainless steel braided line, with a quick fuel 175 pump and a aeromotive billet aluminum regulator
Project -- zephyr 05041512141_zps9qbgz4r8
johndickjr
Post  whitefield May 5th 2015, 12:10 am
Looking good Bud ! Cool
whitefield
whitefield
Post  johndickjr May 5th 2015, 3:07 pm
whitefield wrote:Looking good Bud ! Cool
this is the 393w that put put your cam and stuff in, close to 13-1 compression , with a ported super vic..should pop pretty good
johndickjr
Post  jbozzelle May 8th 2015, 11:03 am
Looks close to the 78 Futura I'm putting back together with parts I've bought from guys on here over the past few years.
Post  johndickjr May 31st 2015, 11:28 pm
went to track , had tranny -converter issues, can moved about 20 ft and rpm went threw the roof let off tried little more throttle..ran 8.54 in the 1/8 at 22 mph and coasted from about the 300 ft mark ended up running 14.21 in the 1/4 at a idle
johndickjr
