XE boss heads
+6
gt350hr
awmach
10 posters
XE boss heads Empty XE boss heads
Post  awmach April 25th 2015, 1:58 pm
I finally mocked up my iron heads so now I have more questions
The intake angle is waay different 5/16 gap at top of ports with a nascar  intake on
Does anyone make an intake that is wider / different angle or sells raw castings?
The spark plugs are in a different spot (true hemi chamber) homemade gaskets or?
It came with Jessels but i was told rockers are different then prodution boss
So what are the diffs? who makes rockers or can I adapter stock cast rockers
What kinda spring pressure / rpm / lift are they good for ?
This is not a max build just a hot rod motor
Thanks in adv!
awmach
XE boss heads Empty Re: XE boss heads
Post  dfree383 April 26th 2015, 3:48 am
Pics?
Post  the Coug April 26th 2015, 8:43 am
sounds like you great deal just got not so great and expensive to boot..
XE boss heads Empty I don't think I can post pics
Post  awmach April 26th 2015, 1:57 pm
I have sloow dial up
awmach
Post  John Myrick April 26th 2015, 2:32 pm
I didn't know dial-up was still around
XE boss heads Empty I live in the woods
Post  awmach April 27th 2015, 10:02 am
I live in the woods not ur world of greed
(Kid Rock)
awmach
Post  dfree383 April 27th 2015, 10:32 am
Well it would really help to see what your describing to help us give you good answers.
Use a protractor and let us know what the intake face angle is on you heads and on the intake you are using. Hemi's and 429/460's have different angles and bolt patterns.
Are you sure your intake is a boss9 part? They made them for wedge heads too.
It may be to your advantage to open a photobucket account and take the time to download some pictures.
Post  John Myrick April 27th 2015, 11:51 am
awmach wrote:I live in the woods not ur world of greed
(Kid Rock)
" Greed is good"
( Michael Douglas - WallStreet )
XE boss heads Empty 87 degrees from face of head
Post  awmach April 27th 2015, 12:24 pm
87 ish degrees 82 is c9 boss I think
awmach
Post  Paul Kane April 27th 2015, 1:11 pm
awmach wrote:I finally mocked up my iron heads so now I have more questions
Thanks in adv!
Some answers may be found...
here:  http://www.network54.com/Forum/85220/thread/1345756103
and here:  http://www.network54.com/Forum/85220/thread/1077814457
Post  gt350hr April 27th 2015, 3:32 pm
awmach,
This is a common problem when dealing with experimental/ prototype parts from Ford. Often a handfull of parts were made only to find they didn't work. 40 + years later we try to use the stuff and find it doesn't use easily available parts. Blue Thinder "might" be able to take one of his repro Boss intake castings and have it machined to your needs. Cushman Competition in Maine "might" have some pieces for the iron heads.
gt350hr
XE boss heads Empty I've completed the valve covers
Post  awmach January 8th 2016, 4:41 pm
this link has a picture
http://grandrapids.craigslist.org/pts/5391735343.html
awmach
Post  supervel45 January 8th 2016, 5:48 pm
(Kid Rock)
" Greed is good"
Fuck Wall Street theiving bastards. Wink
Post  jeffgfg January 8th 2016, 7:26 pm
The cast iron boss 429 heads have a different angle on the intake face of the head, than the aluminum version. I'm not sure if a standard intake can be machined to fit. You might need to add spacers after machining the intake to match the angle of the heads to get everything to line up.
jeffgfg
Post  res0rli9 January 8th 2016, 7:34 pm
awmach wrote:this link has a picture
Thats just a valve cover, can't tell anything by that.
Post  John Myrick January 9th 2016, 8:00 am
supervel45 wrote:
(Kid Rock)
" Greed is good"
Jealousy is such an ugly emotion Razz
Post  BOSS 429 January 9th 2016, 11:21 am
as I said there are 3 diff iron boss 429 heads,and rocker set ups, need pics of what you have in order to help, Yes ive used jesels on the iron heads
