valve lengths
valve lengths
Does anybody know the stock lengths on the frpp scj heads needing some about .100 longer for more lift
fordmonsta- Posts : 236
Re: valve lengths
fordmonsta wrote:Does anybody know the stock lengths on the frpp scj heads needing some about .100 longer for more lift
An intake valve .100"" longer will not work well in an SCJ head. The valve tip gets to close to the intake stud for rocker arm fitment. I have done it but, using a Small Block Ford intake rocker arm.
Re: valve lengths
I'm looking for more installed height right now I'm at 1.900 with a 636/663 lift cam I'm fixin to swap from it to a solid roller with .740/745 is that doable with the right spring
Re: valve lengths
You should be able it pickup .050 with some retainers and .050 with proper locks.
You need proper springs to install at 1.95 or 2.0
Re: valve lengths
I'm running a plus .050 lock alreadythe retainers are a 741 comp locks are 614 comps
