TFS Streets CNC porting options from TFS
+12
83-88T-Bird Guy
IcallhimGeorge
kjett
16 posters
TFS Streets CNC porting options from TFS Empty TFS Streets CNC porting options from TFS
Post  the Coug November 22nd 2009, 9:50 pm
http://www.trickflow.com/pressreleases/powerport325cylinder/
just checked their sight and they have come out with a new CNC ported TFS Street head.... affraid
TFS Streets CNC porting options from TFS Empty Re: TFS Streets CNC porting options from TFS
Post  res0rli9 November 22nd 2009, 9:54 pm
Have them for the A460 head also 355
Post  bruno November 22nd 2009, 10:11 pm
do we have any flow numbers yet ??? did Charlie Evans have anything to do with this new cnc program ??
http://WWW.CKRME.COM
Post  richter69 November 22nd 2009, 10:12 pm
with the "small" valve option.
Post  the Coug November 22nd 2009, 10:25 pm
Bruno you mean our experimentals. I doubt it.....
Post  richter69 November 22nd 2009, 10:41 pm
The experimental heads had extra meat welded in them, to apply that to a std head you will have a dutchlincoln syndrome..............
Post  the Coug November 22nd 2009, 10:50 pm
I am going to be experimenting on mine this winter, I have some Ideas and I think I can make them work....
Post  richter69 November 22nd 2009, 10:54 pm
I might change the oil.......second thought, I wont even do that.................. Laughing
Post  dfree383 November 23rd 2009, 8:07 pm
Some new seats, intake valves and some rubbing willl do small wonders.....
Post  Lem Evans November 23rd 2009, 8:31 pm
c.n.c. k.e.y
Post  kjett November 24th 2009, 8:08 am
So are the CNC versions going to be a generic ported version of the streets or are they supposed to be an out of the box max effort port job? Similar to the way the SCJ and P51 heads sort of line up. I know they are never going to be as good as a set of custom application specific ported heads, but just curious if it would be worth spending the extra money on the CNC's or just get the regular streets and have them ported later.
kjett
kjett
Post  windsor November 24th 2009, 12:51 pm
Hopefully, they'll have them available as products soon on their site to answer all these questions.
Post  richter69 November 24th 2009, 1:00 pm
I just want the "Mafia" intake............ Twisted Evil
Post  the Coug November 24th 2009, 2:20 pm
richter69 wrote:I just want the "Mafia" intake............ Twisted Evil
I would too but I am not going to hold my breath waiting for it... I figure end 2010 or 2011, as for the heads the stock out of the boxes come with 290cc intake ports the C.N.C. are comiong with 325cc that tells me they took alot of meat out.
I feel these heads have a lot of flow still in them, I am working toward finding out.......
Post  kjett November 24th 2009, 2:30 pm
The other thing I noted is the cnc ported heads say 80cc chambers. I thought the normal streets were 74cc chambers. What would be the reason to enlarge the chamber, other than to drop compression?
kjett
kjett
Post  IcallhimGeorge November 24th 2009, 3:52 pm
^^you cant handle TFS streets, be it box stock, ported or CNC'd.
I see procraps in your future. Not only am I a badass.....Im psychic too.
Laughing
IcallhimGeorge
IcallhimGeorge
Post  Lem Evans November 24th 2009, 10:09 pm
CNC's ass....
TFS Streets CNC porting options from TFS 2.350hand002Small
A human did these ports......all a machine does is copy what a person designs [hopefully].
Post  richter69 November 24th 2009, 10:14 pm
Bein' that "they" took a lot of "meat" out, I wonder if "they" might have sent some with the "snake" to get it "swapped"....................in O-hi............ Laughing Laughing
Post  Nevs November 24th 2009, 10:42 pm
Hey now! Wink
Post  Lem Evans November 24th 2009, 10:48 pm
I suspect "they" took a lot of aluminium out of the cyl. head .
Post  83-88T-Bird Guy November 25th 2009, 8:23 am
kjett wrote:The other thing I noted is the cnc ported heads say 80cc chambers. I thought the normal streets were 74cc chambers. What would be the reason to enlarge the chamber, other than to drop compression?
Larger market share for stroker combos on pump gas is one benefit. Right now there are few head choices for a 80-85 cc chamber. Blue Thunder is one and Edelbrock has a 95 cc version.
Beyond that, one would have to step up to A460 TFS to get something bigger than 72-74 cc chambers.
83-88T-Bird Guy
83-88T-Bird Guy
Post  IDT-572 November 25th 2009, 1:43 pm
Hey now! Wink
I will just swap out enough meat to win the turkey.................. Laughing
Post  bbf-falcon November 26th 2009, 11:28 pm
richter69 wrote:The experimental heads had extra meat welded in them, to apply that to a std head you will have a dutchlincoln syndrome..............
Dutchlincoln is designing a new CNC porting program for PROCOMP, and I can't wait. Embarassed Embarassed
Post  the Coug February 9th 2010, 11:52 am
ttt
Post  jones February 9th 2010, 12:54 pm
Has anyone put these heads on a flow bench? How much did they improve the exhaust port? When they say the exhaust was raised .270 is that just the port or port & exhaust bolt pattern?
jones
