The truck is alive and almost ready for KY..
+13
jones
gmsmkr
Coupe Devil
Moodyblues
61coon
David Willingham
17 posters
Page 2 of 2 Previous  1, 2
The truck is alive and almost ready for KY.. - Page 2 Empty Re: The truck is alive and almost ready for KY..
Post  KY JELLY May 28th 2015, 9:03 pm
Do you think that battery set up is going to work well and last ?
KY JELLY
KY JELLY
Post  David Willingham May 28th 2015, 10:15 pm
Yes, I think so. Did you hear it start on my other video in the official truck thread? Plus, the batteries are only $125 each, x2.
David Willingham
David Willingham
Post  IDT-572 May 28th 2015, 10:18 pm
How is recharge time at the track, and how much is the charger?
Post  David Willingham May 28th 2015, 10:22 pm
These batteries have to be stored at 50%. I charged 2 batteries at once from 50% to 100% in about 10-15 minutes on 10 amps. I will try 20 amps next time. probably take 5-10 minutes. This charger setup cost me about $350. I have a backup single charger that cost $80 and it takes it about 1.5 hours each. I plan to swap them out with a fresh pair every run or 2. They cannot be charged on the car or with an alternator. If you have fans and pumps that need to run between rounds, you need two sets of batteries. Swap them out right before you go to the next round. It's a little more work, but they only weigh 1.6 lbs and you lose the big battery(s) and the long cables.
David Willingham
David Willingham
Post  69F100 May 28th 2015, 11:40 pm
David what MAH are your batteries have you seen these to let you know what the battery has left in it.
http://www.ebay.com/itm/New-LCD-Indicator-Battery-capacity-Tester-for-12V-48V-Lead-acid-Lithium-LiPo-/121437987820?pt=LH_DefaultDomain_0&hash=item1c4644a3ec
Post  David Willingham May 28th 2015, 11:49 pm
6600 mah, 25c discharge rate. 6.6 x 25 = amps. I use something similar to check the batteries and I go by the voltage. They need to come off at around 15 volts.
David Willingham
David Willingham
Post  FalconEh May 28th 2015, 11:54 pm
Happy you are going to be ready, I look forward to some video clips...that is one crazy wicked for truck!
Post  665 falcon May 31st 2015, 8:36 am
that's bad MoFO, nice job Dave Very Happy
665 falcon
665 falcon
