Sheet metal vs cast intake
larry552
Sheet metal vs cast intake Empty Sheet metal vs cast intake
Post  larry552 June 2nd 2015, 10:45 pm
For an 1/8 mile drag car big tire 2400lb with 632 will a cast intake or a sheet metal intake better for this combo. Single fogger system.
larry552
larry552
Sheet metal vs cast intake Empty Re: Sheet metal vs cast intake
Post  schmitty June 2nd 2015, 11:26 pm
Phillip got me 1272HP and 1018TQ on a single 4 cast.
Post  dfree383 June 2nd 2015, 11:28 pm
The Ford racing intake works well for the $$$ the sheet metal stuff will make more power but it's at $3000 + an additional carb.
Post  rmcomprandy June 3rd 2015, 9:48 am
When using a Victor ... I know a couple racers who have re-fabbed just the #1 and # 8 runners with sheet metal for a pretty substantial gain with 520/530 sized engines.
SO, sheet metal AND cast you could say. Wink
Post  kim June 3rd 2015, 6:27 pm
Hymmm.... Use plenum and rails... Sheet metal... Wieand Tunnel ram. Might have to get me another and see what can be done. Never even thought about that. Not like aluminum tubing is that expensive.
kim
Post  richter69 June 3rd 2015, 10:51 pm
Philip is porting and welding 16 nitrous bungs in my cast Intake for my 632..... FWIW
Post  Curt June 4th 2015, 8:44 am
richter69 wrote:Philip is porting and welding 16 nitrous bungs in my cast Intake for my 632..... FWIW
But once you start injecting directly into the cylinder, the manifold becomes less of an issue. Jon Kaase told me that if you add N20, the heads don't care if they are just "okay".
Post  Lem Evans June 4th 2015, 9:25 am
If a guy had 1,200 hp rather 1,100 hp ....that's 100 hp of spray a guy does not have to manage.
Post  kim June 4th 2015, 11:28 am
Fewer failure points makes a combination so much more fun to manage.  Problem lies in the already discussed issues of the N2O builds.  If your going to spray player loads you going to compromise max NA performance.
Jon which block are you using to build the 632?  Heads?  And of course this threads subject...  which manifold is getting worked?
kim
Post  Lem Evans June 4th 2015, 1:18 pm
Life is full of compromises. But, putting a mediocre cylinder head on a sprayed 632 engine isn't one I'd make.
Post  kim June 4th 2015, 2:10 pm
Me either.  C. Thor or B441.  Problem is finding some I can afford.
kim
Post  richter69 June 4th 2015, 4:59 pm
Ford c heads, ford c intake, ford a460 block
Post  Curt June 4th 2015, 5:08 pm
richter69 wrote:Ford c heads, ford c intake, ford a460 block
Sheet metal vs cast intake 1276043276202
