DIY Headers
+14
TommyK
bowsher21
bonfire
1982GT
Race Ready Fabrications
Mustang-junky
MustangBBF
18 posters
DIY Headers Empty DIY Headers
Post  MustangBBF June 17th 2015, 11:24 am
Ok - Since no one offered to sell me a set I am forced to build custom headers and wanted to reach out for advisement.
I have a 91 Fox body with a 460, AJE frontend, QuickTime 8010 Manual Bell housing with mechanical linkage, stock speedo cable, Hydro boost.
When I had the PG with Kooks 2 1/8 headers they hung to low and would rip the v-bands off the exhaust all the time. Didn't like the PG anyway so switched to a manual for the fun of it.
I have tried many off the shelf headers and they are sitting low or flat out will not clear my configuration. All have been returned except my original SS Kooks long tubes.
Have access to Mig and TIG, bought flanges, and box of bends. Now I'm looking at this mess a little overwhelmed.
I have tried PVC - melting ends and epoxying stub to flanges and trying to run 90, 45, and 22 degree bends.....Never seems to workout correctly. Taken apart and ends are going to be returned to Homeless Depot.
Next attempt is old pool hose mocked in with TIG wire for strength and then filled with spray foam - is this a crazy idea?
Trying to shave some development time here. I am very handy and not afraid of these custom projects but hate wasting loads time on failures.
Not sure what to do next.
Thanks in advance,
Joe
MustangBBF
DIY Headers Empty Re: DIY Headers
Post  bruno June 17th 2015, 12:52 pm
were are you located ?
http://WWW.CKRME.COM
DIY Headers Empty Location
Post  MustangBBF June 17th 2015, 1:32 pm
Ft. Lauderdale FL.
MustangBBF
Post  jbozzelle June 17th 2015, 2:59 pm
I'd modify the Kooks to fit what you have...
Post  bruno June 17th 2015, 3:04 pm
MustangBBF wrote:Ft. Lauderdale FL.
https://www.facebook.com/DanNeumannRaceCarsLLC
or http://innovativeracecraft.com/Contact.html
both of these folks do great work !!!
Post  Mustang-junky June 17th 2015, 10:30 pm
jbozzelle wrote:I'd modify the Kooks to fit what you have...
This makes the most sense to me.
Jess
Mustang-junky
Mustang-junky
DIY Headers Empty Modifying Kook
Post  MustangBBF June 18th 2015, 11:29 am
There is such a difference in routing between the two bell housings(JW PG and QT 8010) I am remiss to cut up a pair of $1200.00 460 SCJ headers.
I figured a $300 pile of parts is worth a shot in the dark to make a set. Delusions aside this is definitely not a project for the faint of heart as I am finding out.
Maybe I'll picture document my mistakes...errr progress hehehe.
At the very least everyone is helping me achieve the required 25 posts before you can post items to sell.
Thanks!
Joe
MustangBBF
Post  69F100 June 18th 2015, 12:09 pm
You are right when building header it is a pain sometimes trying to figure just where you need to cut tube to come out where you want it scratch
Post  Race Ready Fabrications June 18th 2015, 12:41 pm
My best advice if you're determined to build them yourself is to 'Begin with the end in mind.'
Place the collector where you want it to be for best tranny and ground clearance and build to it. I rarely build a header that all 4 tubes on one side are not independent of one another. This will give you a little more freedom as where to place the tubes as well. Also, I'd recommend buying an assortment of large and small radius J-bends.
DIY Headers Empty Sage advice TY
Post  MustangBBF June 18th 2015, 2:22 pm
TY - very good advice.
MustangBBF
Post  1982GT June 18th 2015, 4:38 pm
I picked up a dynatech header kit from speedwaymotors. It cost around $165 plus shipping, if I remember correctly. The kit even came with flanges. I wish I had better cutting tools while building them,but they turned out ok.
https://s316.photobucket.com/user/z7turbo/library/zephyr%20pics?sort=6&page=4
Above is the link to my build.
1982GT
1982GT
Post  res0rli9 June 27th 2015, 12:49 am
These mite help.
http://www.dragzine.com/news/new-products/icengineworks-releases-welding-clamp-set-custom-header-builds/
Post  bonfire July 17th 2015, 9:00 am
Always thought this looked like a worthshile challenge. anyone ever seen any online tutorials on this process. If not, might I solicit one of you talented fabricators to put your work on youtube
bonfire
Post  MustangBBF July 17th 2015, 12:01 pm
I am documenting my build. In the next week or two should be able to start posting pictures.
MustangBBF
Post  bonfire July 17th 2015, 1:06 pm
Great.... forward to it
bonfire
Post  MustangBBF July 17th 2015, 1:16 pm
Setting the expectation now: I am a shade tree mechanic. Stuff gets done but don't expect show quality. lol.
MustangBBF
Post  whatbumper July 17th 2015, 5:22 pm
All of that is why we get $2000 for our mild steel headers with mufflers. And they are perfect in the end. We have a lot of experience that can not be shared not because we don't want to but because it just takes time to learn it.
we dont use any kind of mock up kits. we place the collector where we want it bolt the flanges on the heads and put a 6" or so piece of hose on the plugs to take up space so you don't make it hard to change plugs. then get after it.
Post  richter69 July 17th 2015, 6:52 pm
^ agree..... Ive always put the flanges on and stuck the collector where it needed to be andgot after it.
Post  bowsher21 July 17th 2015, 8:28 pm
I like to use a standup band saw to cut the tube and you should get a nice 10" or 12" disc sander to face off your tubes after cutting. That will square the faces up for an excellent fit. The better the fit, the better the weld and the better the finished product.
bowsher21
bowsher21
Post  bbf-falcon July 18th 2015, 7:48 am
How would a piece of Flex tubing work to mock up a tube? would this work or no?
Post  bowsher21 July 18th 2015, 8:26 am
bbf-falcon wrote:How would a piece of Flex tubing work to mock up a tube? would this work or no?
There are any number of ways to setup a visual models such as using flex tube. The hard part is transferring it to tube length and angle of cut. I use short sections of 1/8 tig weld wire for distance and angle.
Check this out, If I did more sets of headers I might think about getting this setup.
http://www.jefflilly.com/fabrication/header-fabrication/
bowsher21
bowsher21
Post  TommyK July 18th 2015, 9:35 am
http://www.stainlessheaders.com/headerfabrication
TommyK
Post  jasonf July 18th 2015, 11:15 pm
That is some pretty bad ass info right there.
Post  Super Snake Steve July 19th 2015, 12:34 pm
i seen somewhere looked like they were using those foam noodles that kids use to float in the pool they had them stuck in the flanges and then bent where they needed them to go and I guess copy that with header tube maybe stick a tig wire in the middle to keep it how you want
Super Snake Steve
Post  bonfire July 19th 2015, 5:22 pm
All great ideas. Like to idea of the 6" pieces of hose to account for plug accessibility. Neat trick. Jeff. Lolly link is awesome and the stainless headers link too. MystangBbf. I still look forward to your effort. Will be nice to see something that isn't professional just so I know I'm not alone in this hobby. In the days of Internet some days I feel like I'm the dopiest untalented auto enthusiast in the nation. Seems like everyone can weld 20 gauge aluminum and make it look like a piece of art. Maybe it's just that those who can't do that don't post pics of their work
bonfire
