Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head? Empty Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
Post  DaveMcLain June 24th 2015, 5:07 pm
I was wondering if Jesel rockers that were originally used on a Yates head work on a C-460 head. If they will work I have a great big box full of them and I would love to sell. They are assorted ratios.
DaveMcLain
Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head? Empty Re: Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
Post  c.evans June 25th 2015, 12:43 am
you would need to figure out the pivot length or body length. I believe the C-460 heads use an 1850 body length. The Jesel's you have, you may be able to decode with a jesel catalog and the letters that are stamped into them.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  DanH June 25th 2015, 4:02 am
most Jesel early1.75 pivot, later are 1.85 pivot. push rod offset and stands won't work (both lenght) on intake
DanH
Post  DaveMcLain June 25th 2015, 12:12 pm
c.evans wrote:you would need to figure out the pivot length or body length.  I believe the C-460 heads use an 1850 body length.  The Jesel's you have, you may be able to decode with a jesel catalog and the letters that are stamped into them.
Charlie
Ok. For instance I just picked up one of the rockers and on the bottom it says DDDL 1.90. Another one says DA2R 2.00
DaveMcLain
Post  c.evans June 25th 2015, 1:04 pm
Dave,
I don't have the jesel catalog in front of me, and I'm not going to go get one and do the decoding. All those letters and numbers mean something. For example I "think" on that first one, the last DL means dog-leg. Is it an offset rocker?
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  DaveMcLain June 25th 2015, 1:30 pm
I dug out a catalog and it explains what the codes mean.
DaveMcLain
