Can I use an aluminum spool?
Is it ok for me to run an aluminum spool? My friend has one that I can get cheap. What would be the life of them?
40 spline axles
3200 lbs car w driver
C460 head 600ci (approx 1000hp)
C-6 tranny with t brake
4.56 gears
40 spline axles
4.56 gears
rocketpony- Posts : 120
Re: Can I use an aluminum spool?
you are asking a lot of a spool with that much power with a C6 and 4.56's. I would use a steel one.
whatbumper- Posts : 3024
IIRC aluminum spools were originally meant for dragsters (cuz light weight car) vs heavier door cars. But the Mark Willams catalog says their aluminum spool is also often used in lighter weight/decent HP door cars like Pro Stock & Comp Eliminator. But IMO in the P/S & Comp applications the A/spool most likely becomes a throw away maintenance item.
If you can get the spool for "free" you could take a chance on it. Just don't be surprised if it fails (or "moves around" a bunch & wears out the gear set) at your car's current weight.
DILLIGASDAVE- Posts : 2262
Free race parts can end up being a lot more costly than a new part at top $$$
» Trade for CJ/SCJ/PI Aluminum Valve Covers M/T SBF Black Aluminum Finned
» Spool for 9"
» 8.8 spool
» WTB 8.8 axles ,spool kit
» 8.8 axles and spool
» Spool for 9"
» 8.8 spool
