Complete newbie, feeling out first project
vaehlin
Complete newbie, feeling out first project Empty Complete newbie, feeling out first project
Post  vaehlin July 11th 2015, 8:42 am
Lets start with the amount of experience I have building/working on pushrod engines: zero. I've been absorbing all the knowledge I can across the web, and looking the start my first project in the next few months, and have a few questions.
I'm looking to put together a 450-500 hp foxbody with a 460, mild build, street only. I currently have nothing for it. My total budget, including the transmission, rear end, chassis, and everything I need to make it go is 20k.
Firstly, I'm wondering how practical building vs buying is. A small part of the reason I want to embark on my project is the learning experience of building, but having no practical knowledgebase and no friends/family to pull from, I'm wondering if having someone build the engine for me might be a better path.
Second, if I choose to build, given my lack of experience, I was thinking about using all new parts, including the block, just to eliminate as many potential issues as possible. Is this completely insane given my intended use and budget? I realize this will cost me a decent amount of money, but my goal is to build a bulletproof car, overbuilding is a plus, since I wont be the only common driver, and I'm hoping to not run into things breaking because I skimped in places; a reliable daily driver. It seems like all the build guides for the level of car I want to build, and even most of the crates that are fairly similar to what I'm trying to do use a stock block/heads/crank, with some machine work.
vaehlin
Complete newbie, feeling out first project Empty Re: Complete newbie, feeling out first project
Post  dfree383 July 11th 2015, 9:13 am
Talk to Bob at D&D in Lebanon PA for a complete swap kit.
460 with a C6 and a worked over 8.8 will be the ticket.
Post  cletus66 July 11th 2015, 11:47 am
First thing to do is buy this book:
http://www.amazon.com/How-Rebuild-Ford-V-8-Engines/dp/0895860368/ref=sr_1_1?s=automotive&ie=UTF8&qid=1436629408&sr=8-1&keywords=how++to+rebuild+your+ford+v8
Read it from cover to cover before you do anything else.
Post  bbf-falcon July 11th 2015, 1:33 pm
A lot of this should depend on how mechanical minded you are.Do you have any tools to start out with,such as the ones necessary to assemble the engine.Then you will need a engine lift in which you could rent or borrow. We can help you w/necessary knowledge to perform the task in hand. It brings great self satisfaction to say you built it yourself but sometimes starting out it is a lot less costly and a lot less hassle to buy a similar build to your liking,and get the feel of working on it and go from there. But you have came to the right place for help.We will help as much as possible. Very Happy
Post  BIGINCH'S July 11th 2015, 3:24 pm
For 20k budget you would be much further ahead buying a built car. You will still have plenty of work to do to get your hands on experience.
BIGINCH'S
Post  supervel45 July 11th 2015, 5:12 pm
I would not spend money on a new block for 500HP. Spend your money on new aluminum cylinder heads. You don't need them either, but it will take alot of weight off the front of a Fox body, which is a good thing for traction.
Post  kim July 12th 2015, 8:51 pm
New nlock would be insane for quest.  You have the same 2500 in machine work for a virgin green block as you do a seasoned pick and pull.  FRPP still sells 514cu in stroker 460.  If you want a plug and play.  Virgin FRPP or basic dart etc, unless your buying from a company thats selling it machined and assembly ready..
 Has to have finish machine work done.
kim
Post  supervel45 July 12th 2015, 9:35 pm
Huh, $2,500 for machine work for a stock core block for 500HP. Maybe I read it wrong?^^^^^^^
Post  kim July 12th 2015, 10:31 pm
Depends on what is done, align hone mains, align hone cam bore, size lifter bores, bore hone block, sonic test before any machine work, etc..
All required for 500? No, Could probably get away with simple check for cracks, bore, hone, wash and go.........
All required on virgin green block, yes. Unless sold otherwise, and cost would reflect it.
And I was wrong, FRPP no longer offers the 385 series engine. They have a 427 cu in small block at 575hp, but everything is now on Windsor/boss block.
kim
Post  supervel45 July 12th 2015, 10:53 pm
OK, I got you. I was thinking of the last sentence, on the second paragraph of you above post. Good machine work does add up quick, though. I used to have a deal with my core yard, and he would let me pick and chose, and bring back, if a block was cracked or had a major flaw. There are a 100 ways the OP can skin this cat. He will have to make some decisions, before he can get much more good advice I believe.
Post  bonfire July 16th 2015, 5:28 pm
I think its very doable. you picked the right chassis as everything you need is bolt on , no custom fabrication required. With that said you're first project will be a big one and at some point you will feel overwhelmed. My best advise is start with a running car begin with the small projects first, (replacing suspension pieces, preparing rear axle, updated brakes, new fuel system etc. ) before you get to the engine swap. the longer you can keep it running the less likely you are to get overwhelmed and lose interest in the project. Ask me how I know. My first big project ended up on a rotisserie after I had a master cylinder go out. We often learn more from our mistakes than from our successes....the down side of that in this hobby is that your mistakes are usually fairly expensive
bill
bonfire
