Retard timing
Retard timing
Anybody chime in on this going to run 250 shot where should I start with timing retard at. Is it 2% for every 50 shot. Thanks Dave
dave d- Posts : 809
Re: Retard timing
Iron heads or aluminum?
Where is total now?
What fuel?
progressive controller?
All this helps to know if you put it on the edge you will gain a little more than a book setting
Where is total now?
What fuel?
gmsmkr- Posts : 1364
Re: Retard timing
Aluminum 290 port trick flows 110 fuel running 34 timing and a 1050. 4150 carb. Unfortunately the intake I'm stuck with is a torquer 2 for hood clearance. And running 10.-1 pistons.
dave d- Posts : 809
Re: Retard timing
With that combo I would set it at 26 total and a little fat then creep down on it and adjust timing as needed.... remember new plugs no idle time roll it to line and shut it down past the stripe
Re: Retard timing
^^^^ I agree you should be able to remove 8^ as opposed to 10^with enough fuel especially w/alum heads as a safe point, are using a retard box? If this is a new test pilot effort be careful of the RPM chips and the activations nos doesn't like rev limiters.
FalconEh- Posts : 1448
Re: Retard timing
6al box open throttle switch rev is set at 7200 shift at 6400
dave d- Posts : 809
Re: Retard timing
dave d wrote:6al box open throttle switch rev is set at 7200 shift at 6400
You are gonna put your eye out Dave.
Re: Retard timing
Last small block combo, pulled the 8100 rev chip out when I juiced it and hit 8500 ...slept on the shift or the car picked up Good thing the chip was removed or the internals would have been too!
Re: Retard timing
bbf-falcon wrote:dave d wrote:6al box open throttle switch rev is set at 7200 shift at 6400
Not his eyes but the guys next to him will be like
