Should I and would I benefit from power glide?
+8
1982GT
D. Sea
rocketpony
12 posters
Should I and would I benefit from power glide? Empty Should I and would I benefit from power glide?
Post  rocketpony July 27th 2015, 1:18 am
Currently has a c6 rolerized, brake, custom converter in 3200 lbs back halfed mustang 600ci approx 1000hp, 4.56 gears that is drag raced mainly for heads up racing.
Sum guys are telling me to switch to a power glide, would I benefit from this? How? Faster?
rocketpony
Should I and would I benefit from power glide? Empty Re: Should I and would I benefit from power glide?
Post  the Coug July 27th 2015, 3:02 am
I would go glide, with that much HP why do you need such a low gear and it is pretty much useless you are only in low gear for a second and then you shift.. use the HP and then you only have to shift once and let it eat....
Post  maverick July 27th 2015, 8:31 am
If it was mine it would have a 'glide in it. But at your power level and weight...don't go cheap. Get a good one.
Post  cool40 July 27th 2015, 8:48 am
At 3200# i dont know if i would. Suspect
Post  D. Sea July 27th 2015, 11:21 am
My car is 3212 # with driver. When I switched from a C4 to a Glide I picked up ET and MPH. Approximately 825hp NA.
D. Sea
D. Sea
Post  the Coug July 27th 2015, 2:33 pm
cool40 wrote:At 3200# i dont know if i would. Suspect
Lee I have a friend that has a 3800 lb chevelle runs in the 8s running a glide and when he launches it, it's wheels up every time
Post  rocketpony July 27th 2015, 3:41 pm
D. Sea wrote:My car is 3212 # with driver.  When I switched from a C4 to a Glide I picked up ET and MPH.  Approximately 825hp NA.
Wow that's impressive, if that's the case then goin from c6 to glide should be even more gain.
What was specs on both trannies?(aluminum drum, brake, rolerized, etc)
rocketpony
Post  D. Sea July 27th 2015, 4:01 pm
C4 was rollerized and built. Worked great behind a 466 but didn't like the extra torque from the 534. Glide is rollerized as well with JW Case, pan, bell and tailshaft.
I used to run a C6 when I was running a FE. After racing with this glide for about 7 years now, I won't go back to a 3 speed. I find the 2 speed much more consistent.
D. Sea
D. Sea
Post  rocketpony July 27th 2015, 4:25 pm
I see, thanks for the replies.
Ultimately I want the tranny that will make my car the quickest in 1/4 mile
rocketpony
Post  1982GT July 27th 2015, 9:20 pm
D. Sea wrote:C4 was rollerized and built.  Worked great behind a 466 but didn't like the extra torque from the 534.   Glide is rollerized as well with JW Case, pan, bell and tailshaft.
I' m running a 466 and a C4. In your personal experience, how much power would your C4 take and still be reliable?
Thanks.
1982GT
1982GT
Post  cool40 July 27th 2015, 9:29 pm
i'm always the poor sob that has to be the exception. Laughing i went to the glide from a c4 and did not gain any et or mph! Most folks have better luck than me i guess.
Post  IDT-572 July 27th 2015, 11:06 pm
Thanks.
Its the torque in the lower rpm's that kill the C4's............ It seems that somewhere between 650 and 700 ft lb's is where we have seen them start giving trouble. It seems they will live behind a 800 hp small block and die behind a 800 hp big block.
Post  richter69 July 28th 2015, 8:31 am
Glide and a good converter for the win.
Post  yellowhorse7 July 28th 2015, 9:07 am
Thanks.
EXACTLY what killed mine
yellowhorse7
yellowhorse7
Post  68formalGT July 28th 2015, 1:59 pm
How about the t400 with the 2nd gear transbrake?
Post  maverick July 28th 2015, 8:20 pm
68formalGT wrote:How about the t400 with the 2nd gear transbrake?
I guess you could make a T400 work like a 'glide. It's been done before. But if you want a trans that works like a 'glide...why not just get a 'glide? Wink They're everywhere and EVERYBODY has parts and knows how to build one.
Post  supervel45 July 28th 2015, 9:29 pm
http://www.yellowbullet.com/forum/showthread.php?t=544261 Alot of info on 2speed T-400's.
Post  whatbumper July 28th 2015, 10:55 pm
We build a lot of powerglides and 400's both two and three speed.
A glide with a good 1.80 gearset would be where I would stay with your setup.
If you were using a power adder and wanted to leave on more power then I would say move to either a 1.58 glide or a two speed 400. We sell multiple gearsets for the 400 but the factory 1.48 gearset is the most popular. It's good to a lot of horsepower (I have a couple promod guys using a stock gearset with good shafts and other good internal components.
Post  the Coug July 31st 2015, 6:19 am
1.69 low gear Glide why have the hassle of a T400 and more weight and much more bulk when Millions of Glide running as much or More hp than you and Part are way Easier to find......than some Odd balled Bastardized T400...JMHO
