Ford racing valve covers
Ford racing valve covers Empty Ford racing valve covers
Post  NO FAIR August 1st 2015, 1:36 am
Hi All,
Has anyone had clearance issue with there valve springs hitting the side of the covers? My number 5 exhaust valve spring is rubbing the inside where the indentation groove where it bolts to the head. Is it normal to have to clearance these valve covers? I think I just need to hog the holes out just a touch and push the valve cover down a little so it clears. Am I on the right track?
Thanks for any input.
Dave
Smile
NO FAIR
NO FAIR
Ford racing valve covers Empty Re: Ford racing valve covers
Post  Gregaust August 1st 2015, 5:20 am
I haven't personally but have read on here of that issue before
Gregaust
Post  jbozzelle August 1st 2015, 10:08 am
P51 or SCJ heads?
If so, you'll need to grind the inside of both covers to get that spring to clear. Check clearance through a full rotation cycle of the spring. I had to take off more than I thought I would.
Post  NO FAIR August 1st 2015, 10:46 am
Yes SCJ
NO FAIR
NO FAIR
Post  rmcomprandy August 1st 2015, 11:59 am
NO FAIR wrote:Hi All,
Dave
Smile
Most just need a slight barbering the inside of that bolt column and then twist the cover on installation, counterclockwise as much as you can with the bolts loosely installed.
A 1.630" O.D. spring needs more. Personally, I use a "beehive" spring on the exhaust side with a SCJ head whenever it warrants.
Ford racing valve covers Empty Yes
Post  460Dave August 31st 2015, 7:12 pm
My P-51 heads with 1.65 valves rubbed. I had to "massage" them a bit and they work fine now.
460Dave
