hp with 437
hp with 437 Empty hp with 437
Post  slowjoe August 6th 2015, 7:57 pm
I have a 437 short block and plan on using the 290 tfs heads and intake now and a custom cut solid roller. The short block has flat tops and 0 deck,stock rods and crank. What do you guys thank the hp will be on this setup?
slowjoe
hp with 437 Empty Re: hp with 437
Post  dfree383 August 6th 2015, 8:35 pm
What Pistons? Machine work? Specs on cam? Intake? Carb? Headers? Any port work?
Post  slowjoe August 6th 2015, 8:53 pm
It's just forged flat tops 0 deck. Hooker super comps,out of box 290s and tfs street intake,850dp carb, and have someone cut the cam to what I have.
slowjoe
Post  dfree383 August 7th 2015, 7:03 am
You should see in the 500-525 range pretty easy.
