B&M Pro Stick Shifter
B&M Pro Stick Shifter Empty B&M Pro Stick Shifter
Post  Copperhead August 10th 2015, 10:51 am
I changed some things around in the cab of my truck and had to go with a different shifter w/ rear exit cable and I have my B&M Shifter 4-Sale.   It's in perfect working condition.
I used this on my C-6 transmission.   The shifter covers several different applications, both regular & reverse valve bodies.
It's the old style, part # 80701
New version is part # 80706
http://www.summitracing.com/search?PageSize=100&SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=bmm-80701
http://www.summitracing.com/search?PageSize=100&SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=bmm-80706
Only difference is the newer style includes the cover.
I had to purchase separately.
Included in the sale is the following,....
Cover that I got years ago from Jegs, that's made from Stainless Steel, instead of Aluminum.  Been discontinued for a while now.
Shifter Knob w/ Button - part # 46112
http://www.summitracing.com/search?PageSize=100&SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=bmm-46112
Gate Plate - part # 80710   (Allows the use of a Reverse Valve Body)
http://www.summitracing.com/search?PageSize=100&SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=bmm-80710
Only thing that I don't have to make this complete, is the cable.   I was able to use it on my new shifter.
These are normally $40-50,.....depending on the length you need and where you purchase it.
$175 shipped  (Cont 48 ONLY)
B&M Pro Stick Shifter 11880669_856639444384895_5606551887123647750_n
B&M Pro Stick Shifter 11855913_856639464384893_1038633932029102301_n
B&M Pro Stick Shifter 10983184_856675474381292_8809889789251127133_n
B&M Pro Stick Shifter 11822452_856675487714624_2880266933475100139_n
B&M Pro Stick Shifter 1514621_856675511047955_4081841034423633478_n
B&M Pro Stick Shifter 11855827_856675537714619_7684179968157972993_n
Copperhead
Copperhead
B&M Pro Stick Shifter Empty Re: B&M Pro Stick Shifter
Post  Copperhead August 10th 2015, 4:00 pm
SOLD
Copperhead
Copperhead
