Dynamic compression formula
Dynamic compression formula Empty Dynamic compression formula
Post  747JetMech August 10th 2015, 6:26 pm
Guys
Is there a formula to figure out dynamic compression ratio? Is fuel octane chosen with dynamic or static compression?
747JetMech
747JetMech
Dynamic compression formula Empty Re: Dynamic compression formula
Post  supervel45 August 10th 2015, 6:37 pm
http://www.wallaceracing.com/dynamic-cr.php
Post  DanH August 11th 2015, 10:42 am
want the real D comp ratio? when building the engine it can be got easy.
short block and cam dialed in,one head on (#1cyl) . lifters ,pr's, rockers on and adjusted.
bar crank over till intake valve is(just closes. now measure #6 piston from deak. that distance is now the stroke number. use that number and bore for cubic inch. the rest is just like finding static compression ratio.
That c/r is the real D/ratio
DanH
Dynamic compression formula Empty Dynamic Compression
Post  69BOSS August 14th 2015, 12:27 am
I have been playing around with the calculator and cam profiles, trying to get a dynamic ratio of 8.2 to 8.3:1 for a pump gas engine. One thing I found that I never thought about before is how much late intake valve closing point reduces cubic inch displacement. A 545 CI with a mild cam, intake closing at 71 degrees ABDC, reduces CID to just 403 CI. In comparison, a 466 CI street engine with an intake closing at 59 degrees has 379 CI. Only 24 CI difference. Take the 545 CI and close the intake at 81 degrees and the CID is only 360 CI.
69BOSS
69BOSS
Post  supervel45 August 14th 2015, 12:41 am
So what HP did 1 point of static compression increase did a 545 with the same cam pickup?
Post  DanH August 14th 2015, 4:53 am
69BOSS wrote:I have been playing around with the calculator and cam profiles, trying to get a dynamic ratio of 8.2 to 8.3:1 for a pump gas engine. One thing I found that I never thought about before is how much late intake valve closing point reduces cubic inch displacement. A 545 CI with a mild cam, intake closing at 71 degrees ABDC, reduces CID to just 403 CI. In comparison, a 466 CI street engine with an intake closing at 59 degrees has 379 CI. Only 24 CI difference. Take the 545 CI and close the intake at 81 degrees and the CID is only 360 CI.
"only".more to it than the cubes at the d/ratio cubes
DanH
