Trying to do a search on the site box -
Trying to do a search for "best 429 truck cam" and I get no results.
What am I doing wrong?
Bob
Tucson
Bob
Tucson
75truck- Posts : 102
Re: Trying to do a search on the site box -
There is no best off the shelf grind for one combo you want to match the cam to your combo and desired rpm and off idle specs....
Tell us more about your build....
1) heads
2) Compression
3) intended use
4) rpm range you want to shift and most time spent in
1) heads
2) Compression
3) intended use
gmsmkr- Posts : 1364
Rebuilding Truck
My 75 ford 3/4 ton F250 is getting a new engine - Street driven - changing my c6 out to a zf5speed with a 370 rear gear. Want a nice performing street truck - some towing - but mostly a weekend driver.
But my question is mostly how do I search most effectively?
Bob
Tucson
Bob
Tucson
Forget the search, give more information, and ask more questions...you can't believe everything you search on the internet
FalconEh- Posts : 1448
75truck wrote:Trying to do a search for "best 429 truck cam" and I get no results.
Bob
Tucson
To answer the basic question, the search for this site is flaky. Many times I have gotten "No results found" for the most common of terms.. like SCJ, or 521, or Pro-Comp
Sometimes the advanced search with certain selections is the way to go.. again it's flaky
I can tell you there are not many threads on 429 truck street cams here esp. with 5 speeds. You might try Pirate 4X4 or some of the other truck websites. If you want a Custom Grind there are plenty of guys here for that, and you might be better off going that way, if you know your exact combination.
supervel45- Posts : 4498
» Search ???
» C-HEADED MANIFOLD DISTRIBUTOR ?
» Search guru's
» Craigsligt Search
» In search of something for Autometer Gauges
» Search guru's
» Craigsligt Search
