C6 help. Truck pushes hard
C6 help. Truck pushes hard Empty C6 help. Truck pushes hard
Post  HorsinAround September 4th 2015, 5:17 pm
Went to push my project out to the paint booth, and it pushed hard enough going forward and pushed harder going backwards. Took the drive shaft out and the truck pushed very easy. Everything in this trans is brand new, and hasn't had fluid pushed through it yet. (was hoping to start the motor in a week or so). The trans has been sitting for probably a year now after I assembled it. Is it normal for them to be tight like this at first? If not what should I look at/for?
http://www.frontpagefab.com
C6 help. Truck pushes hard Empty Re: C6 help. Truck pushes hard
Post  whitefield September 4th 2015, 5:52 pm
HorsinAround wrote:Went to push my project out to the paint booth, and it pushed hard enough going forward and pushed harder going backwards. Took the drive shaft out and the truck pushed very easy. Everything in this trans is brand new, and hasn't had fluid pushed through it yet. (was hoping to start the motor in a week or so). The trans has been sitting for probably a year now after I assembled it. Is it normal for them to be tight like this at first? If not what should I look at/for?
Check band adjustment.
whitefield
whitefield
Post  Frank Merkl September 5th 2015, 1:13 am
always pushes harder backwards as the sprag holds and your turning all the internals backwards
