Crankshaft Pulley Spacer
Does anyone sell 4 bolt crankshaft pulley spacers for the 460 engine? Most that i see fit the 302,351 engines?
I am going to add a crank trigger wheel on front of my stock 4 bolt harmonic damper. My current pulley is a 2v with built in 7/8" extension behind the 2v's. shaped like a bell.
If i use a flat pulley with no extension, just flat 2v pulley with the 3/8" thick wheel mounted on front of damper, I will need to space the flat pulley out a 1/2" if my math is correct. so that my belts will line up to the accessories, alternator, ac and power steering.
I am looking for a .500 spacer. any ideas?
jfalbo2015- Posts : 3
Re: Crankshaft Pulley Spacer
Must not be much demand for a crankshaft pulley spacer due to the fact that most crank trigger setups are used for racing
applications with almost no accessories. I am going to fabricate a 1/2" spacer to put behind my flat crank pulley when i install
the trigger wheel. Until then I will just use the stock distributor. I posted this hoping that the spacers were readily available somewhere
as i do not keep up with the new aftermarket parts market.
Thank you.
Thank you.
jfalbo2015 wrote:Must not be much demand for a crankshaft pulley spacer due to the fact that most crank trigger setups are used for racing
Thank you.
Call Keith he can build you one and a great guy to deal with
Thanks a lot guys! I plan on continuing to make parts to support the 429-460 crowd.
My best marketing....has been racer to racer.
Keith Fulp
678-458-2033
You are welcome and welcome to the best BBF site on the net we have venders on here for about anything you need for a 385 BBF.
I just noticed this post.
I have 1/4" spacers for the 4-bolt.
I think I have an aluminum one already on the shelf, but can quickly make up steel or aluminum spacers.
Just give me a call any time.
Nights and weekends ok.
678-458-2033
Thanks,
Keith
678-458-2033
Thanks,
Keith
» crank pulley and alternator/fan/pulley options?
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» Acc. Pulley set
» Does anyone know where i can get a 4 bolt crank pulley like this
» need pulley help
» Acc. Pulley set
» need pulley help
