Breather set up for valve covers
Breather set up for valve covers Empty Breather set up for valve covers
Post  6jeff6 October 19th 2015, 1:35 pm
I have a chrome ford racing breather in each valve cover. After a couple runs at the track they both leak some with passenger side leaking worse and smoking happens from oil getting on header.
Is there a way I can run hoses or something instead of letting it leak out and cause smoke? If so please step me in the right direction because I'm afraid when I do a class next year they may shut me down.
6jeff6
6jeff6
Breather set up for valve covers Empty Re: Breather set up for valve covers
Post  supervel45 October 19th 2015, 1:41 pm
Vacuum pump. You could do a panvac to the headers also.
Post  6jeff6 October 19th 2015, 2:07 pm
Do u have a link or something where I can see it? Is there a kit and/or what would you recommend?
6jeff6
6jeff6
Post  supervel45 October 19th 2015, 2:11 pm
http://www.jegs.com/i/Moroso/710/25900/10002/-1
Post  supervel45 October 19th 2015, 2:15 pm
6jeff6 wrote:Do u have a link or something where I can see it? Is there a kit and/or what would you recommend?
Vacuum pump sized for your application.
Post  6jeff6 October 19th 2015, 2:17 pm
Thank you very much. Damn I owe you a case a beer by now!
6jeff6
6jeff6
Post  supervel45 October 19th 2015, 2:22 pm
Are you running mufflers? They recommend not using it with them, so you might ask around. If the mufflers are low enough restriction you might get by.
Post  6jeff6 October 19th 2015, 2:30 pm
They are low restriction mufflers. Flowmaster little ones basically flow right thru. I am kicking around the idea of running just headers nothing else
6jeff6
6jeff6
Post  supervel45 October 19th 2015, 2:38 pm
There where three or so other kits on the link I posted. Some were less then the Moroso, so it's cheap and easy to try. If it does not work out no biggie. You can make a few passes uncapped and see if it helps your time any, it is the only way I know to tell.
Post  6jeff6 October 19th 2015, 2:51 pm
That's the sucky part. It takes some full throttle blasts at track to see if it works but from what I've read you are spot on. Well I guess I can either cut out mufflers or just run open headers and scare children haha
6jeff6
6jeff6
Post  supervel45 October 19th 2015, 2:55 pm
http://www.jegs.com/c/Exhaust-Headers-Mufflers-Cat-Back-Kits_Exhaust-Cutouts/11529/10002/-1 Or.
Post  6jeff6 October 19th 2015, 3:04 pm
That would work perfect and give me what I'm looking for
6jeff6
6jeff6
Post  supervel45 October 19th 2015, 3:14 pm
Sounds like you are ready to Smoke some Shelby, now. You want to go hunting, I think there may be one in Bama to bust up?
Post  6jeff6 October 19th 2015, 3:20 pm
Haha was great to run a 10.4 but there was an 03-04 cobra running 8.9 that was impressive. He also used his own stuff to pour in burnout box which I hate.
And if it's the one you told me about I need nitrous and lots of it!
6jeff6
6jeff6
Post  supervel45 October 19th 2015, 3:23 pm
For the slug I am talking about you will not even have to open the bottle, I bet. Cool
Post  6jeff6 October 19th 2015, 3:26 pm
There was a super snake I'd like to revisit now that I have my chit together. But he was from mn and only there for muscle car day.
Maybe a winter run south after I get cut outs and oil vacuum system installed
6jeff6
6jeff6
Post  6jeff6 October 19th 2015, 3:39 pm
Should I do 4" cutouts at collector or after it goes to 3" put just before muffler
6jeff6
6jeff6
Post  supervel45 October 19th 2015, 3:39 pm
He will probably have it blown up by then, and his wife will pull the plug, better hurry. Razz
Post  supervel45 October 19th 2015, 3:43 pm
6jeff6 wrote:Should I do 4" cutouts at collector or after it goes to 3" put just before muffler
I would paint those pipes and make a full pass, and see where the paint burns back to. Cut the pipes there and put the 3"'s if you can where the burn ends.
Post  6jeff6 October 19th 2015, 3:55 pm
Muffler is only a couple inches behind collector so I would literally have to put right there if I want to keep exhaust where it's at.
6jeff6
6jeff6
Post  supervel45 October 19th 2015, 3:55 pm
6jeff6 wrote:Haha was great to run a 10.4 but there was an 03-04 cobra running 8.9 that was impressive. He also used his own stuff to pour in burnout box which I hate.
NO. I would not do that to you, that one goes 8.60's. Shocked I am talking about the one with all the red junk under it.
Post  6jeff6 October 19th 2015, 4:00 pm
That's hauling!
6jeff6
6jeff6
Post  supervel45 October 19th 2015, 4:01 pm
6jeff6 wrote:Muffler is only a couple inches behind collector so I would literally have to put right there if I want to keep exhaust where it's at.
I would go with the 3" cutout. Put it where you can, but don't go redesign the whole exhaust system for them. I don't think they will help anyway, or very little. You probably would be better off skipping all of this and putting your money towards a Vacuum pump, especially if you ever intend to spray it.
Post  6jeff6 October 19th 2015, 4:13 pm
Chit okay I'll start pricing vacuum pump stuff as I will spray next summer for sure
6jeff6
6jeff6
Post  6jeff6 October 19th 2015, 4:23 pm
Holy crap which vacuum pump set up is tried and true?
6jeff6
6jeff6
