Valve Body C6
Valve Body C6 Empty Valve Body C6
Post  Tore Fri 23 Oct 2015 - 19:11
Is there any way to look at a valve body and determine if its a Rev shift or Standard shift pattern without installing it in the tranny?
Tore
Tore
Tore
Valve Body C6 Empty Re: Valve Body C6
Post  Frank Merkl Fri 23 Oct 2015 - 20:44
if theres no passages in the spacer plate for the modulator valve it will be a reverse pattern
Post  Tore Sat 24 Oct 2015 - 20:18
Frank Merkl wrote:if theres no passages in the spacer plate for the modulator valve it will be a reverse pattern
Frank I have no idea of what your even talking about. Do you have a picture you can post?
Tks Tore
Tore
Tore
Post  supervel45 Sat 24 Oct 2015 - 21:20
https://2img.net/h/i227.photobucket.com/albums/dd3/BobbyFord_2007/IMG_1238.jpg I believe he is talking about the slots at the passenger rear of the separator plate, that is exposed, that connect to the vacuum modulator ports in the case.
Post  supervel45 Sat 24 Oct 2015 - 21:23
Scroll down in the link for picks. Right behind the triangle alignment plate held down by one bolt.
Post  Tore Sun 25 Oct 2015 - 14:31
Thanks I got it.
Tore
Tore
Tore
