BBF in A Fox - Cooling Rad/Fans
BBF in A Fox - Cooling Rad/Fans Empty BBF in A Fox - Cooling Rad/Fans
Post  MustangBBF November 6th 2015, 2:13 pm
Before I detail - Yes I used the search button at the top and went through all old posts. Very Happy
This is a street BBF Fox (Mild at 400 HP to the rear wheels)
My clearance is 3" between snout and Rad cores (Basic Alum Flexcool 24X19X2 Rad). My Volvo/Mark 8/Traditional 3000+ CFM pullers will not work.
Flex and Derale both make a 1 5/8 or 1 3/4 but CFM is low for our BFF 2200 ish.
Can everyone with a street BBF in hot climates chime in (Florida/Texas, Arizona, etc.) on what their rad size is and fan configuration? Pics would be awesome!
I am not against angling the rad or customizing but would like to see what those with more experience have already done. I'm not sure any OEM aftermarket pusher will cool our motors.
Let me have it.....
Thanks Joe
MustangBBF
BBF in A Fox - Cooling Rad/Fans Empty Re: BBF in A Fox - Cooling Rad/Fans
Post  gmsmkr November 6th 2015, 2:56 pm
I recessed my rad in side the core support top built a tubular lower and I'm running duel ford contour fans 2200 each wired them so they both come on with toggle switch.
I'm also using a electric water pump
I will get you some pics later.
gmsmkr
gmsmkr
Post  kim November 6th 2015, 7:07 pm
I just trimmed the mark viii fan shroud box down to 1/4 depth
kim
Post  Mark Miller November 8th 2015, 2:17 am
MustangBBF wrote:Before I detail - Yes I used the search button at the top and went through all old posts. Very Happy
Let me have it.....
Thanks Joe
I'm using a Howe Aluminum Radiator i want to say a "19x31" with a water pump driven fan with 5.0 serpentine pulley and 5.0 serpentine crank pulley and 5.0 Mustang shroud
BBF in A Fox - Cooling Rad/Fans MarkMillers346
Post  Mark Miller November 8th 2015, 2:19 am
I might be able to e-mail some better pictures if interested.The picture i posted i had on photobucket.
BBF in A Fox - Cooling Rad/Fans Empty Found a fan at the junkyard this weekend
Post  MustangBBF November 9th 2015, 1:47 pm
Looked interesting so I grabbed it.
A 16" specialty pusher fan from a BMW 5/7 Series
It is purpose built as a pusher and looks like it uses the same motor from the Volvo/ford fans. It pushes a lot of air.
I'll try to post a pic later.
MustangBBF
