SCJ rockers?
gmsmkr
YellowStangDuane
SCJ rockers?
Looks like Jegs/Summit want around $430 for the Harland Sharps. Cranes are about the same price. Am I missing something? Are they cheaper somewhere else? I'm almost thinking if I'm spending that much, go with the Cranes? I think Lunati has some around $300, Trick Flows are $300, what do y'all recommend? Open to any vendors that sell them too, not just the normal mail order guys.
YellowStangDuane- Posts : 76
Re: SCJ rockers?
I have the S4073 on my combo
gmsmkr- Posts : 1364
Re: SCJ rockers?
If you want the best stud mount rocker (in my opinion) go with Crower stainless steel. Cost more but it'll be the last set you buy.
Re: SCJ rockers?
x3!David Cole wrote:If you want the best stud mount rocker (in my opinion) go with Crower stainless steel. Cost more but it'll be the last set you buy.
Re: SCJ rockers?
The 1830-16 ultra pro magnum xd chromoly steel rockers are very good stuff. $407
http://www.compcams.com/Products/CC-%27Steel%20Stud%20Mount%20Rockers%27-0.aspx
Re: SCJ rockers?
YellowStangDuane wrote:Looks like Jegs/Summit want around $430 for the Harland Sharps. Cranes are about the same price. Am I missing something? Are they cheaper somewhere else? I'm almost thinking if I'm spending that much, go with the Cranes? I think Lunati has some around $300, Trick Flows are $300, what do y'all recommend? Open to any vendors that sell them too, not just the normal mail order guys.
I use Lunati rockers all the time on SCJ heads, and they work great.
Carl- Posts : 284
Re: SCJ rockers?
If you have a below max effort build then Scorpions may be a good fit. They are made in the USA.
Dave De- Posts : 797
Re: SCJ rockers?
Lunati or Trick Flows seems like a choice. Leaning toward the Tricks.
Re: SCJ rockers?
When I bought the heads, I bought the SCJB's but got talked out of running a roller. It is a .600 lift solid FT cam, switching to Comp 930 16 springs. Not sure of pressures. Is that $407 from you direct Lem?
Re: SCJ rockers?
YellowStangDuane wrote:When I bought the heads, I bought the SCJB's but got talked out of running a roller. It is a .600 lift solid FT cam, switching to Comp 930 16 springs. Not sure of pressures. Is that $407 from you direct Lem?
With a 930 spring you do not have to have the 1830 rockers for your application.
The 1630-16 rockers are better than you would have to have for a flat tappet spring....~ $350, and yes. I will match Summit's price on these rockers.
Re: SCJ rockers?
Sounds good, ready to order!
Re: SCJ rockers?
Lem talked me into buying the good ones! Killer price on them too. Thanks again!!!
Re: SCJ rockers?
YellowStangDuane wrote:Lem talked me into buying the good ones! Killer price on them too. Thanks again!!!
Thanks !
» I.D these rockers
» Jesel BBF (used)rockers and stands
» 1.7 rockers for 5.0
» Crane roller rockers new price SOLD
» Iron heads boss 429 EX part#
