7.3 needs help
7.3 needs help
I have a 2000 F250 with 7.3 diesel 5spd. The problem is it has a p0279 code no. 7 injector circuit loe input and a p0470 Exhaust Back preasure sensor circuit . It smoke misses and low power. I forgot to add one more code it is a p1267 cylinder no. 7 high to low side short. It just started doing this no warning or anything. I need some help on this one.!
whitefield- Posts : 2244
Re: 7.3 needs help
unless its been addressed already the inj harness will work lose under the vc, pop the ps cover off and you will see in not snapped in. Ford sells some clips that go under the lock to keep it from coming out.
The locks sag and then they work loose.............very very common problem.
Re: 7.3 needs help
The owner just replaced the vc gaskets and wiring harnes. He bought them from carquest and they are made by Dorman. He also stated that it runs worse now than it did before.
Could the ones he put on be bad?
Re: 7.3 needs help
could have knocked a bail clip loose on an injector, easy to do putting the cover on.
Re: 7.3 needs help
I'd take a look at it. Mine ran like crap before I replaced the harnesses and gaskets.
jbozzelle- Posts : 3705
Re: 7.3 needs help
I got it fixed! I took it back apart double checking everything and finding nothing wrong with the new Harnesses and valve cover gaskets . I put it all back together and fired it up same thing . So I put the old ones back on and it fixed it after putting some black tape on the skined wires from the old harnesses.
Thanks for your help.
Bad parts that are from CHINA!
CHINA PARTS ARE KILLING us.
Re: 7.3 needs help
whitefield wrote:I got it fixed! I took it back apart double checking everything and finding nothing wrong with the new Harnesses and valve cover gaskets . I put it all back together and fired it up same thing . So I put the old ones back on and it fixed it after putting some black tape on the skined wires from the old harnesses.
Or whomever skinned up your wires.
longroofracer- Posts : 250
Re: 7.3 needs help
Harness was probably skinned from rubbing on the pushrods. Get the harnesses from International or Ford.
Re: 7.3 needs help
jbozzelle wrote:Harness was probably skinned from rubbing on the pushrods. Get the harnesses from International or Ford.
good advice, i've prolly done a 1000 of them....(and thats not an exaggeration)and never had one of the ford/international parts fail.
Re: 7.3 needs help
Yea That is what we plan on doing. I just put the old ones back on to see if the new one were at fault and to get back to the orignal problem. Either way thanks and I got the customer going down the road and the new stuff from ford on the way.
