comp ultra pro magnum 1830-16
any one on here using the comp 1830-16 rockers with a solid roller and trick flow street or 325 heads , if so what length push rods did you use . I need a starting point , thanks
10SHOTS- Posts : 587
» comp ultra pro magnum 1830-16
» COMP Cams 841-16 Endure-X, Sheet metal valve cover, Ultra Pro Magnum roller rockers
» Scorpion 1023 vs Comp 1830
» Roller Rocker not hitting valve squarely
» COMP Cams 34-229-4 - COMP Cams Magnum Hydraulic Cam/Lifters
