one bad 4x4 must see!!!!!!!!!! 4.99 in the 1/8
Larry T
fastford600
sorry it aint a ford but this is wild!!!!!!!!!!!!!!!!!
https://www.youtube.com/watch?v=ztUwfLQPEao&feature=player_embedded
fastford600- Posts : 391
Re: one bad 4x4 must see!!!!!!!!!! 4.99 in the 1/8
i wish i could find a ford truck like this!!!!!!!!!!!!!!
check this bad mo forker out!!!!!!!
https://www.youtube.com/watch?v=BQD-eLWLMO4
Larry T- Posts : 1076
cmon these are all chebbies...like we dont see enough of them...lol
73f100shortbox557SCJ- Posts : 93
yea that nice but i am a drag racer sorry no more diry for me!!!!!!!!
I saw that truck in person a week ago. It was at my track running ORSCA. It's a wild setup. Got to give him points for being different. The engine is NOT a chevy. 541 ci Oldsmobile. screw type supercharger makes 52 psi boost.
David Cole wrote:I saw that truck in person a week ago. It was at my track running ORSCA. It's a wild setup. Got to give him points for being different. The engine is NOT a chevy. 541 ci Oldsmobile. screw type supercharger makes 52 psi boost.
that is nasty!!!!!!!!!!!!!!!!
used to be a bronco on the old site pulling the front wheels in 4x4. not as fast, but very impressive
Dave Maxwell- Posts : 576
We talked to him and looked over the truck at the last ORSCA event at Montgomery. It still has a lot of bugs to work out. The owner is a mud bog / fast track chassis builder and has to rework the rear 4-link for drag racing. Right now the rear isn't getting enough mechanical advantage due to how it's setup. It just takes time and he had to start some where. He is getting a good idea of what needs to be changed to get the truck to work right.
jones- Posts : 2230
so what do you think it will go when he gets the bug out?
logan
logan
Well, being that he says he only uses 2 of the gears in the transmission and the truck won't leave or either starts to spin on the top end I see no reason why it couldn't run 4.70's. I think it's a 4 speed trans that he doesn't like, using a centrifigal (sp) clutch. If I remember correct he wanted to go to a brunodrive / lencodrive. Very nice guy, just not use to building a drag car, much less a 4wd drag car.
Due to running that clutch setup his best rt was something like a .120 He said he tries to almost red light to get even that! Hard to red light on a pro-tree when it's that slow to respond!
jones- Posts : 2230
