AFR
samiam
AFR  Empty AFR
Post  samiam Sun 27 Dec 2015 - 2:20
what  are your thoughts on these heads, just saw the add today, and curious for some input  as per trick flow..,,http://www.enginelabs.com/engine-tech/cylinder-heads/tech-deep-dive-air-flow-research-bullitt-cylinder-heads-for-bbf/
Last edited by samiam on Sun 27 Dec 2015 - 2:28; edited 1 time in total (Reason for editing : better)
samiam
samiam
AFR  Empty Re: AFR
Post  supervel45 Sun 27 Dec 2015 - 2:45
http://www.enginelabs.com/engine-tech/cylinder-heads/tech-deep-dive-air-flow-research-bullitt-cylinder-heads-for-bbf/ If you edit a post the link usually messes up.
AFR  Empty Re: AFR
Post  rmcomprandy Sun 27 Dec 2015 - 14:07
The opinions just don't matter and their viability is in how they actually run so, no kind of advertising will be a very substantial substitute.
They seem to be some good pieces however, their proof will be in how they perform.
AFR  Empty Re: AFR
Post  dfree383 Sun 27 Dec 2015 - 14:29
Are they avaliable? Avaliable for real?
AFR  Empty Re: AFR
Post  res0rli9 Sun 27 Dec 2015 - 14:37
dfree383 wrote:Are they avaliable? Avaliable for real?
Yes they are. your Buddy on the other site bought a set & is getting another set.
You know the Mad Hatter Razz
AFR  Empty Re: AFR
Post  NITROUS FORD Sun 27 Dec 2015 - 20:28
was reading about them myself seem like a good street/strip head for the bbf engine. looking at the flow#'s it seems to me that they were going after the p51 heads in creating them! seem like a good head but we will see when somebody has some dyno#'s on a engine with them Shocked
NITROUS FORD
AFR  Empty Re: AFR
Post  samiam Tue 29 Dec 2015 - 1:26
Thanks for the help,,,,,,,,,
supervel45 wrote:http://www.enginelabs.com/engine-tech/cylinder-heads/tech-deep-dive-air-flow-research-bullitt-cylinder-heads-for-bbf/                                             If you edit a post the link usually messes up.
samiam
samiam
AFR  Empty Re: AFR
Post  supervel45 Tue 29 Dec 2015 - 3:51
You're welcome. You need to buy a set of those heads and test them out so we can see what gives. Hopefully they are as good as their SBF heads?
AFR  Empty Re: AFR
