comp 1630-16 1.7 ford spec ?
whats the deal with these rockers...? there a 1.7 and not 1.73 but they are ford spec not chevy. any pros and cons as far as geometry goes? I know a lot can be corrected with the proper length push rods and such. not much loss in valve lift I assume.
torino501- Posts : 417
Re: comp 1630-16 1.7 ford spec ?
torino501 wrote:whats the deal with these rockers...? there a 1.7 and not 1.73 but they are ford spec not chevy. any pros and cons as far as geometry goes? I know a lot can be corrected with the proper length push rods and such. not much loss in valve lift I assume.
They are based upon Chevrolet rocker bodies however, the stud hole in the trunions have been offset drilled so, they are not in the center of the point of trunion rotation making the rocker itself sit farther away from the spring and valve like some shaft rockers do.
rmcomprandy wrote:torino501 wrote:whats the deal with these rockers...? there a 1.7 and not 1.73 but they are ford spec not chevy. any pros and cons as far as geometry goes? I know a lot can be corrected with the proper length push rods and such. not much loss in valve lift I assume.
what type of build would somebody use these rockers...? I guess ive got a lead on some new ones very cheap. and id guess id build the valve train around it..(push rods). but if the geometry is way off hell I don't want them either...
» Small block Ford comp cam Solid roller
» 8896 Dominator, Ford C4 Bell,Used Comp Roller Lifters
» Hooker Super Comp HPC Coated Fox Big Block Ford Headers
» Open Comp - Pro Comp class NMRA
