500cu+ SOHC vs. 572 A-head
dcon
500cu+ SOHC vs. 572 A-head Empty 500cu+ SOHC vs. 572 A-head
Post  dcon November 30th 2009, 11:08 am
Hey guys,
I guess I have someone with plenty of dough gunning for me this summer. What's the power potential for a SOHC? 500 plus cubes... I think he's gonna have about 521. Mine has maybe 800 now... sending my heads to Charlie porting this winter... maybe a bigger stick.
Any idea's?
dcon
500cu+ SOHC vs. 572 A-head Empty Re: 500cu+ SOHC vs. 572 A-head
Post  the Coug November 30th 2009, 11:17 am
I would get with Lem and have him cut you a new Cam for your setup and go ..... most I have seen out of an SOHC is about 700. but you have a much superior setup to his....
Post  rmcomprandy November 30th 2009, 12:24 pm
RPM potential is what will decide the outcome here and how high in the RPM range each engine will perform; more gear ratio requires less input power.
Post  dcon November 30th 2009, 12:27 pm
I guess I shoud've stated... he has an aluminum block too. But... my car is pretty light. I have billet crank and rods....diamond pistions... I spin it to about 7500 normally. Should be interesting.
dcon
Post  windsor November 30th 2009, 5:34 pm
Well, if Jay Brown is doing the motor, the power potential is much higher than that 700. I believe the SOHC's he uses in Drag Week are knocking on the 900's in the hp department.
I say don't worry about the Fords...go out and smoke some Brand X stuff!
Post  dfree383 November 30th 2009, 8:24 pm
windsor wrote:Well, if Jay Brown is doing the motor, the power potential is much higher than that 700. I believe the SOHC's he uses in Drag Week are knocking on the 900's in the hp department.
that one had a bunch of way over the top machine work, but is cool.
You should be able to get 950-1000+ with the a heads and a single 4 no sweat at 572".
Post  c.evans November 30th 2009, 8:38 pm
I'll agree with Dave, because we made 1031 Hp with my 572 CID engine back in June 2008. It used our CNC ported TFS A-460 heads, dry sump, and the tunnel ram and 2 X 4 set-up. So,,,,,,knock off 65 Hp or so for the other carb, and a rightous 572 single carb deal should make around 965-970 Hp.
Phillip's TFS A-460 headed engine was more impressive than mine, in terms of Hp per CID, and he had even a bigger engine. These deals need to be well thought out, and you need to get with Lem on the appropriate camshaft, also the pistons and ring package.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
