Why aftermarket blocks are a good idea if you going to get at it......
http://www.stangtv.com/news/video-blown-big-block-ford-engine-on-dyno-with-a-twist/
Re: Why aftermarket blocks are a good idea if you going to get at it......
As read on here time and time again, the girdel is good for holding all the parts together when they grenade...........
FalconEh- Posts : 1448
IDT-572 wrote:As read on here time and time again, the girdel is good for holding all the parts together when they grenade...........
Kinda like one of the plastic things that holds a 6 pack together!
Did this thread switch to guns or was it a metaphor
FalconEh wrote:Did this thread switch to guns or was it a metaphor
I like guns.....
Me too...The question I have is would the stud girdle protect the internals from Mike's BMGdfree383 wrote:FalconEh wrote:Did this thread switch to guns or was it a metaphor
I like guns.....
FalconEh wrote:Me too...The question I have is would the stud girdle protect the internals from Mike's BMGdfree383 wrote:FalconEh wrote:Did this thread switch to guns or was it a metaphor
I like guns.....
I would speculate that the results would be similar to the artical...... It would nearly hold it all together but still be trashed
I like guns.....
I like turtles
Mike R- Posts : 1381
Mike R wrote:dfree383 wrote:FalconEh wrote:Did this thread switch to guns or was it a metaphor
I like guns.....
I like turtles
Oh do tell......
after reading the article and the comments posted. to me it looks like the 8k rpm killed it. why only 12lbs of boost? leave the rpm at or below 7k and just add more boost..? even though it had alum rods im sure that crank has a lot of reciprocating weight at 8k rpm. that's just dumb..
torino501- Posts : 417
This is just more proof that some people have more $$ than brains!!!
wickettoby1- Posts : 352
We do 70% nitro on blown Fords with OEM blocks and they live, and we're generating more power than the engine in the article. Come on out to this year's March Meet at Bakersfield and see for yourself.
What killed the engine in the link above was: completely wrong application/setup of a passenger car block. Generally, the blower tugs the long snout, which see-saws on the #1 main and thereby excessively loads the #2 2-bolt main cap, plus a main girdle with stronger aftermarket studs (<-----BIG mistake there) plus the high rpm. If I were there I could have called out this failure just before the actual pull.
Judging by the pictures, my guess is that the #4 main web let go first, then the rest followed suit. Had they stuck with OEM main bolts and kept rpm down, the odds of that engine living would have been ten-fold (excepting for the risk of cracking the #2 main cap). Ideally on a Roots-type blower engine they should have 4-bolted the block while staying with the OEM bolts....especially when they attempted the increased rpm.
I'm thinking the small ass 8-71, 21# and 8000 rpm all came into play
Getting greedy withe the wrong parts
Yeah to be fair I should also acknowledge that an aftermarket block would have indeed given them all the wiggle room in the world.dfree383 wrote:I'm thinking the small ass 8-71, 21# and 8000 rpm all came into play
Getting greedy with the wrong parts
With the OEM stuff in order to have a good chance of success one must have a good understanding of the correct setup and applications when utilizing them.
hell I totally misread the part about the 21 psi and 7k rpm... then to 8k.
torino501 wrote:hell I totally misread the part about the 21 psi and 7k rpm... then to 8k.
And only a 8-71 blower.......
» Good weekend with good folks!
» No more aftermarket iron blocks
» converter swap gets me a 10th
» Fabbed Motor Plates?
» Turbo setup for my 429 looking for a little more hp good or bad idea?
