I need a oil pan what do you suggest?
jones
The oil pan I have on the engine right now will not clear the cross member in my truck. I is a FRPP oil pan that has a windage tray and crank scraper. It's considered a rear sump but it has a small sump in the front. The small sump is causing all the problems. I thought about cutting the sump out but I don't think that would be the best option.?? ( Lem told me this pan he sold me was one of the best pans out there and they are no longer made. I'm thinking it would be worth more if I don't cut it up.)
Canton makes this pan that will work but it's not as nice as the current pan. http://www.summitracing.com/parts/ctr-16-774
Should I not worry about it and just go with the Canton or try to look for something better. This is going in my 1994 f150 4x4.
PS. I am still in the market for a set of valve covers. I was going to order the fabricated Canton valve covers but I have read that some have problems keeping them sealed.
jones- Posts : 2230
Re: I need a oil pan what do you suggest?
Don't forget the oil pump under that little front sump.
cool40 wrote:Don't forget the oil pump under that little front sump.
This is beyond the clearance needed for the oil pump. The oil pump only requires 6 to 6-1/4" where this is 7-3/4 to 8" from the pan rail.
jones- Posts : 2230
Break out your cutting wheel and section a piece of the cross member, then weld in steel support to make it strong. It will not hurt anything.
BBFTorino- Posts : 999
BBFTorino wrote:Break out your cutting wheel and section a piece of the cross member, then weld in steel support to make it strong. It will not hurt anything.
I was going to do this until I got a good look at it. The swing arms attach exactly where I need to make the cuts. My idea was to cut out a section on either side of the cross member. Then come back with a 3x3 or 2x2 angle. It's the worst place I could cut into the crossmember, I would be cutting into the swing arm bracket and have to remove one of the mounting bolts.
jones- Posts : 2230
Moroso's fox pan is 6-1/2" in the front. I think Canton has a fox pan that is 6-1/4" in the front.
If your looking for something custom that doesn't have a custom price contact this guy. I found him at the Chili Bowl and does some amazing work.
Doug Lee - Top Cover 918-542-4686 www.propan.net
Curt- Posts : 2791
Lem Evans wrote:Moroso's fox pan is 6-1/2" in the front. I think Canton has a fox pan that is 6-1/4" in the front.
Do any of those have the same features this pan has? (What's your thoughts on the pan I posted a link too?) I like the pans that don't require me to drain oil from little front sumps. I want you to get what I need sent to me.
I'm using a bare block now for drivetrain fitting. I can wait toward the end to make the oil pan swap.
jones- Posts : 2230
If you don't want a fox style just use the Carton truck deal or a Moroso 20614....6-1/2" in the front.
http://www.summitracing.com/parts/mor-20614/overview/
It has screen rather than a louvered tray.
Happens to me all the time, Lem. For all kinds of things where the customer really does not have all the facts.
Customers ask for something specific, (like a rear sump oil pan or a Fox chassis pan to also fit a truck), when what they really need is something else, (one simply to fit the truck).
Then they realize when they get the oil pan, it really wasn't what they wanted, (but got what they asked for).
pan interchanging
Thats part of our beloved Ford down fall, parts interchangeabilty they car less about. They have the deminsions at Ford but don't EVER use them to to simplify things. And our eyes are'nt as good as used to be lol.
ED468- Posts : 200
I'll have y'all know Lem had this pan that was part of the engine package I bought from him. I bought it thinking it might fit. Guess what, it didn't fit. I'm not asking him to give me a refund or anything. I'll keep it and maybe use it down the road. Lem just told me if I could make this pan work it would be a good deal as it has all the stuff in side. As usual Randy, I don't know what your talking about unless Lem posted something I didn't see.
jones- Posts : 2230
Can you set the engine back a little to clear it?? How about raising it up some??
error: dbl post
jones- Posts : 2230
BBFTorino wrote:Can you set the engine back a little to clear it?? How about raising it up some??
I did try this but there is not enough room. I'll just order the canton 4x4 pan and be done with it. Since I was going to spend $400 for another pan I just wanted to make sure I wasn't buying a crappy part.
I have used shims under the motor mounts before but I don't want to do that here. I have set a thin piece of wood under between the oil pan and cross member, tighten the motor mounts then removed the wood. Had a perfect gap.
jones- Posts : 2230
ditch the mounts, use motor/mid plates and set the motor where you want. It will be cheaper than buying another new pan. Besides you mentioned before that that is mainly a drag truck with some street, so do some fabricating and make it work.
kjett- Posts : 1169
That is an idea. I can't go any further back unless I drop the engine lower into the frame rails. Or do some cutting on the fire wall.
jones- Posts : 2230
Or trim some of the cross member and shim the motor mounts up some....
kjett- Posts : 1169
I did swap the rubber mounts for a set of solid mounts. The mounts I got from L&L where just too soft. I couldn't imagine them holding up to very many transbrake launches.
jones- Posts : 2230
PS.. I can't really imagine a whole pile of other parts either!
jones- Posts : 2230
