How the heck
gmsmkr
How the heck Empty How the heck
Post  jasonf February 13th 2016, 1:14 am
How the heck do you install steel wheel tubs. The cardboard mockup slips right in but I know the steel will not be so forgiving. Every article/video I can find shows how to make them and then magically they are in the car. It is a street car so I wanted to stay with steel tubs. I'll post some pics tomorrow.
How the heck Empty Re: How the heck
Post  cool40 February 13th 2016, 3:45 pm
Time......lots of it! Smile
Post  res0rli9 February 13th 2016, 4:02 pm
fold or strap the ends that go to the 1/4 panel in as much as you can will help.
Post  gmsmkr February 13th 2016, 5:29 pm
A plasma and a welder Razz
gmsmkr
gmsmkr
Post  Mike R February 13th 2016, 10:45 pm
Hammers and band aids
Post  DILLIGASDAVE February 15th 2016, 6:22 am
Installing a "2 piece tub" (1 flat part attached to 1 curved part) can be a pain some times. Some people take the curved part (before trimming it to size to fit the fender) and cut it in 1/2. Then you overlap the 2 halves (using 1 to 2 inches of overlap) and drill a line of rivet holes (on aluminum tubs), or weld (steel tubs) to attach the 2 halves back together during the install. Doing this creates a "3 piece" tub, and makes the flat part & the inside-half of the curved part easy to install. Then you trim to fit & install the outside-half of the curved part. Doing it this way (3 pc tub) doesn't look as good, but it is a little easier than a 2 pc tub.
Post  jasonf February 15th 2016, 10:13 pm
Sorry I forgot to post pictures.
I thought about cuttiing them and making two pieces, then weld it back together in the car. A bunch of work but will be my last resort.
How the heck 93de315c-6067-4c39-9f77-2598873a2d79_zpsrbrh9xs1
How the heck 20160213_143752_zpsi2sfah5t
How the heck 20160213_091011_zpsof1yu5se
Everytime I trim sheet metal I find more rust. I removed the rest of the trunk floor at the back so I can pull the rear section of the quarter out to help. It's not much but anything will help.
Like my "restored" car. lol.   That's almost 1/2" of bondo.
How the heck 20160214_104648_zpsnkaycdj2
Post  John Myrick February 16th 2016, 6:05 am
Looks like you will be getting plenty of cutting and welding practice
Post  res0rli9 February 16th 2016, 7:37 am
Well once you cut that rot affraid the tubes will fall in
Post  jbozzelle February 16th 2016, 9:51 am
So those tubs don't have the Pittsburg lock seam?
Post  jasonf February 16th 2016, 9:57 am
res0rli9 wrote:Well once you cut that rot affraid  the tubes will fall in
I was thinking the same thing but I don't want to cut up the outside of the car yet (another project for another day).
jbozzelle wrote:So those tubs don't have the Pittsburg lock seam?
No I rolled a 45* bend on each piece and welded them together to make a radius corner.
How the heck 20160212_171318_zpswqu73d9z
Post  jbozzelle February 16th 2016, 11:23 am
You can cut the welds and install them as two pieces now...
Post  TravisRice March 9th 2016, 9:37 pm
It takes some patience and finesse but they will go up in without cutting them. I've put a few sets in and never destroyed or bent them beyond repair. They usually give enough not to crease as you work them in. Try putting the side facing the quarter panel up in first with the vertical part of the tub on about a 45 degree angle down towards the floor. As you work the front edge up in the back side should allow itself to start upwards. Your going to have to keep working the quarter panel side making sure it gets tucked up in past the wheel lip as you go.
Travis
Post  jasonf March 9th 2016, 10:02 pm
I had to go home for a funeral so progress has stalled a bit. I did manage to fab up the other one on the weekend. I rolled the outside edge on the drivers tub because I like that look better. I need to trim the passenger side and roll that to match. They are large tubs so it won't cause any issues with the tire. Plus with the 64 Falcon the qtr panel is in and out and in and out so it will still be wider than the narrowest part of the qtr ( if that makes sense). It has been real humid here so I am waiting for it to dry up a bit so I can paint the area back behind the tub because one they are in they will never come out.
How the heck 20160306_163041_zpsfe4ujmy2
How the heck 20160306_163240_zpsgklju45t
Post  jasonf March 9th 2016, 10:04 pm
TravisRice wrote:It takes some patience and finesse but they will go up in without cutting them. I've put a few sets in and never destroyed or bent them beyond repair. They usually give enough not to crease as you work them in. Try putting the side facing the quarter panel up in first with the vertical part of the tub on about a 45 degree angle down towards the floor. As you work the front edge up in the back side should allow itself to start upwards. Your going to have to keep working the quarter panel side making sure it gets tucked up in past the wheel lip as you go.
Travis
I did trim the rest of the trunk along the bottom of the fender (it was rusted anyways) to aid it pulling out the panel a bit to help. I could see alum flexing in a lot more than that 16 ga metal. I am going to try my best before I trim anything but I will be surprised if it fits. Shocked
Post  TravisRice March 10th 2016, 7:33 pm
Travis
16 gauge........ ain't going to go up in like I said. Most wheel tubs that are steel are 20-22 gauge.
Post  jasonf March 10th 2016, 11:39 pm
Hahaha I know. This is a street car with no bar/cage so I wanted to put some strength back in the rear of the car. With no sheet metal back there the 2x3 rear frame rails are surprisingly flimsy when I have my fat butt on the rear of the car. Smile
Post  gmsmkr April 1st 2016, 10:43 am
Mini tub using stock inner tubs and moving them in 3"s
How the heck 20160329_221537_zpskbmklo7m
gmsmkr
gmsmkr
