alum to alum
61coon
GT300TD
alum to alum
I have M/T aluminum valve covers and 1/2" spacers. I want to bond them together permanently to avoid using 2 sets of gaskets. Have looked on the "net" and everything is so expensive, plus I want to be sure that anything I buy will withstand the heat. Besides two sets of gaskets are 'fugly' .
GT300TD- BBF CONTRIBUTOR
Re: alum to alum
JB Weld maybe ?
John Myrick- BBF CONTRIBUTOR
Re: alum to alum
I've not had the best luck with JB weld , but I think it might have been in the preparation. I'll probably use it, thanks.
Re: alum to alum
There is a 2 part system called "5 minute epoxy". Devcon is the manufacturer. Good stuff!
61coon- Posts : 1824
Re: alum to alum
GT300TD wrote:I have M/T aluminum valve covers and 1/2" spacers. I want to bond them together permanently to avoid using 2 sets of gaskets. Have looked on the "net" and everything is so expensive, plus I want to be sure that anything I buy will withstand the heat. Besides two sets of gaskets are 'fugly' .
If you bond it to the cover having well cleaned surfaces with "the right stuff" being sure to allow it a full week to dry, you will have no issues. Cut off the excess after it dries with a razor blade.
Re: alum to alum
Or some 3m yellow weather adhesive for weather stripping
Re: alum to alum
Duck tape it Terry.
Re: alum to alum
I guess you have considered different "tall" valve covers?
Re: alum to alum
I saw a t.v. commercial for that Mighty Putty it's gotta be good.Guy glued a hard hat on his head and is hanging from a steel beam.
biglucky- Posts : 213
Re: alum to alum
cool40 wrote:I guess you have considered different "tall" valve covers?
Yes, but my M/T's look so 'right' on the '64 Galaxie.
Re: alum to alum
Okay, sand w/60 grit paper and clean with brake fluid. Find the right stuff, JB Weld or the epoxy or the mighty putty (I'll check them out). Clamp and let cure for 1 week.
Thanks a lot guys .
Thanks a lot guys .
Re: alum to alum
Something else to consider. I used to paint a lot of Harley engine parts and because the aluminum was so porous the paint would start to blister after they got hot from the oil trapped in the castings. To solve the problem we would clean them then put them in the oven for about an hour at 450 degrees, let them cool and clean them with brake clean. Problem solved
Mike R- Posts : 1381
Re: alum to alum
The valve covers are in vgood shape, thanks for the tip.
Re: alum to alum
I've got a set of those M/T's Terry. Pretty cool covers.
Re: alum to alum
bbf-falcon wrote:I've got a set of those M/T's Terry. Pretty cool covers.
I have 2 sets, bought both of them at the Super Swap
Re: alum to alum
Picked up some JB Weld Marine Weld, it's the only JBW that lists Aluminum in the Applications.
