oil pan
Bart Knox
oil pan
I was going to use the ford racing oil pan for my 95 bronco but ended up useing a 92 f250 pan. My question is. Is the high volume pump and pick up that would go with the ford racing pan work with the factory pan? They look vary similar.
Re: oil pan
It should fit with no problems.
jbozzelle- Posts : 3705
Re: oil pan
The HV pump is slightly longer.
Re: oil pan
M84D melling pump is the one I am looking at getting but I cant find the pick up like the one in the ford racing oil pan kit on the summit website that You can buy individually
Re: oil pan
Go to the local parts store and get one for a 92 f250
Re: oil pan
Also. I no this is sort of off topic but I need a rad. F series rads for 460 were listed 80-87 and 88-96. The motor is a 77 and bronco is 95. Does it matter witch one I get?
Re: oil pan
I would go with the 88-96 for a 460 so it will fit the body without problems. Stay away from the diesel radiators as I believe the core supports were different.
supervel45- Posts : 4499
Re: oil pan
I have read a few times that the diesel rad was different. Thanks ill go with the 88-96 rad.
Re: oil pan
Right on. I was useing the single core 302 rad that was in the bronco had to leave double fans non stop to keep the motor at running temp. I got a price from the shop in the city that does the rad work on the skidders and equipment at work and was $200. I think thats a good price from the canadian dollar right now definately cheaper than the local parts store.... Thanks
Re: oil pan
I've been searching around trying to figure out what I'm going to do about motor mounts. Are the diesel engine mount towers the same as 460? I've been calling local scrap yards looking for 80-96 460 mount towers and not having any luck but seen on goggle images of diesel towers and they looked the same?
Re: oil pan
I have a diesel radiator if you need one.
Re: oil pan
Bart Knox wrote:I've been searching around trying to figure out what I'm going to do about motor mounts. Are the diesel engine mount towers the same as 460? I've been calling local scrap yards looking for 80-96 460 mount towers and not having any luck but seen on goggle images of diesel towers and they looked the same?
I'd like to know this too. I plan to drop a 460 into a f350 frame that had a 6.9 diesel originally.
Jess
Mustang-junky- Posts : 438
