15x10.5 8 bolt rims?
Bart Knox
15x10.5 8 bolt rims? Empty 15x10.5 8 bolt rims?
Post  Bart Knox March 24th 2016, 1:17 pm
Iv seen some truck's 250s and 2500s with 8 bolt 15 inch rims. I have a set of supper swamper boggers 15 11.5 38.5 tires I bought for my Bronco and I'm thinking about putting them on my f250 diesel 92. I've seen some pictures on goggle of the calipers ground down 1/2 an inch to clear the 15s. Has someone done this or no another way of making this work?
Bart Knox
Bart Knox
http://W. B Knox&son LTD Huntsville Ontario
15x10.5 8 bolt rims? Empty Re: 15x10.5 8 bolt rims?
Post  Bart Knox March 24th 2016, 3:41 pm
15x10.5 8 bolt rims? 2016-010
Bart Knox
Bart Knox
Post  Mike R March 24th 2016, 7:14 pm
Not a good idea
Post  Bart Knox March 24th 2016, 7:25 pm
It will be for offroad use only. I have a new set of calipers I would switch after the weekend.
Bart Knox
Bart Knox
Post  norm March 24th 2016, 8:15 pm
Can get wheels with real shallow back spacing, so the wheel lip is as far "outside" of the calipers as possible.
norm
norm
Post  Bart Knox March 24th 2016, 9:11 pm
Ok I'll look into that. Ill see if there's a number Bart wheels tec support.
Bart Knox
Bart Knox
Post  Bart Knox March 24th 2016, 9:39 pm
I emailed Bart Wheels wonder if I'll get a deel being named Bart lol. Who els does custom wheels?
Bart Knox
Bart Knox
Post  Bart Knox March 28th 2016, 10:50 am
Bart wheels said they don't go further than 3 1/2 inch backspacing. Think that would work... $65 a piece at summit
Bart Knox
Bart Knox
Post  460bronco March 30th 2016, 12:32 pm
Thats weird... I have some 2" backspace bart wheels. 15x8's w/ 5x5.5" pattern. I needed the smaller back spacing to give a little more turning ability w/ my maddog fenderwell exit headers.
460bronco
460bronco
Post  Bart Knox March 31st 2016, 6:45 pm
That's what they told me for 15-8 6.5 8bolt. 3 1/2 backspacing...... If someone has a link for 2 inch backspacing for 8 bolt rims that would be great I'll check them out. I've been searching around but can't find anything over 6 wide with 2 inch backspacing.
Bart Knox
Bart Knox
Post  460bronco April 1st 2016, 9:30 am
It was a special order deal directly from Bart. You aren't going to find them at summit, etc.
460bronco
460bronco
Post  Bart Knox April 2nd 2016, 9:10 pm
I did call and thats what they said... I'll call again and be more specific and really press "CUSTOM"
Bart Knox
Bart Knox
Post  56f100guy January 14th 2017, 9:31 pm
Custom rims? Call John at Stazworks. I had a set of double headlocks custom made and they were phenomenal..
56f100guy
Post  SandHillsHillbilly January 15th 2017, 2:51 pm
Yes another vote for Staz wheels. If you care which you might not with Swampers but you might have trouble balancing use beads or centric balancers.
http://www.centramatic.com/balancers.rhtml
SandHillsHillbilly
SandHillsHillbilly
