what gas should i run?
DaveMcLain
racinghabbit
what gas should i run? Empty what gas should i run?
Post  racinghabbit March 30th 2016, 12:56 am
street and strip motor ... 13.8:1 compression ratio... iron heads... 650 hp (roughly) .. I am wondering what gas i should run.????  vp c12 seems to be recommended.  motor only turns 6000 rpm... Can i run 110 turbo blue with an octane booster/??? Thanks
racinghabbit
racinghabbit
what gas should i run? Empty Re: what gas should i run?
Post  supervel45 March 30th 2016, 7:49 am
I would not run octane booster in race gas. Not saying it would not work but, I have never had very good results with the stuff when I tried it with pump gas. Can you get Sonco Purple 110? I think it would squeak by with your compression and it seemed to run better for me then the Turbo Blue.
Post  DaveMcLain March 30th 2016, 5:22 pm
I think that 110 leaded would be perfectly fine as long as your tune up is good.
DaveMcLain
Post  FalconEh March 30th 2016, 8:55 pm
racinghabbit wrote:street and strip motor ... 13.8:1 compression ratio... iron heads... 650 hp (roughly) .. I am wondering what gas i should run.????  vp c12 seems to be recommended.  motor only turns 6000 rpm...  Can i run 110 turbo blue with an octane booster/??? Thanks
110 is probably sufficient, but I wouldn't bother with the octane booster. For my street car I usually mix mine with 50/50 C-16 / 92 when I plan on nitrous passes, or C-12/92 for cruizing. My street car is a small block with less compression 12.69:1 and 2-stages of nitrous with a high limit of 8500rpm cost per gallon of race fuel got me into mixing and keeping on the tune has proved it works.
Post  supervel45 March 30th 2016, 9:17 pm
I used to spray a lot on my 12.5 smallblock also with 110, no problems.
Post  racinghabbit March 31st 2016, 11:17 pm
sonoco supreme 112 i have been learning about... if i can get it locally .... sonoco says its only a dollar more than 110.... Thanks for all the feed back .
racinghabbit
racinghabbit
Post  DILLIGASDAVE April 2nd 2016, 6:01 am
Is using E-85 an option since it's a street/strip combo, and not a daily driver or towing/mileage deal?
Post  6jeff6 April 3rd 2016, 11:57 am
That's a nice looking truck! In the 4s in 150 feet?
6jeff6
6jeff6
Post  schmitty April 8th 2016, 8:57 pm
VP113
