Very Rare Holley 780 CFM Vacuum Secondary Carb.
https://www.dropbox.com/s/jbrnfjlni7kfd0y/2016-03-30%2021.59.21.jpg?dl=0
Forgot I had it laying around. Pulled it completely apart and cleaned and inspected it meticulously. Every thing except accelerator pump diaphram and power valve in excellent condition. This is a quasi emissions performance carb. with 600cfm size primaries and 800cfm size secondaries with a square flange base and Ford A/T kictown provision. With a mild 460 you should see double digit gas mileage, maybe even in the teens, that only might be surpased by a Quadrajet carb.. These carbs are rare and the only ones that I know that are harder to come across are the 6708 and 6709 650cfm and 750 cfm double pumpers with Ford A/T Kickdown square flange spreadbore. These ( This one and the 650 cfm version ) are their Vacuum secondary brothers. It will include a chrome fuel line with gauge port, spare metering block and metering plate/rear bowl gasket and I will get a new power valve the size of your choice ( it has a 7.5" now ) as well as a new accelerator pump diaphram. All other parts are in good runable condition, and it also has high flow needle and seats. It has 66-2 jets ( factory stock ) and a #42 metering plate. I will include some larger jets also.
More Pictures Coming soon.
Date Code: 2997
$175.00 plus shipping.
Date Code: 2997
supervel45- Posts : 4499
Re: Very Rare Holley 780 CFM Vacuum Secondary Carb.
https://www.dropbox.com/s/r0gd0b10xvlt1xh/2016-03-30%2019.43.46.jpg?dl=0
Updated Pictures
https://www.dropbox.com/s/03vl4jotg9jnx08/2016-03-30%2021.58.46.jpg?dl=0
https://www.dropbox.com/s/in35gaqg0ps8dqp/2016-03-30%2021.58.57.jpg?dl=0
https://www.dropbox.com/s/cxw2r4n4spcqkvb/2016-03-30%2021.59.01.jpg?dl=0
https://www.dropbox.com/s/aa9mb2pejb1l7xe/2016-03-30%2021.59.07.jpg?dl=0
https://www.dropbox.com/s/yoybjxovdm4rk51/2016-03-31%2006.16.24.jpg?dl=0
https://www.dropbox.com/s/uyocrrqsjwi3f7c/2016-03-31%2006.16.33.jpg?dl=0
https://www.dropbox.com/s/dtyusicego12840/2016-03-31%2006.16.57.jpg?dl=0
https://www.dropbox.com/s/fprfhvpdqtyhgh8/2016-03-31%2006.17.07.jpg?dl=0
https://www.dropbox.com/s/xp66dppwcao3l3p/2016-03-31%2006.17.16.jpg?dl=0
https://www.dropbox.com/s/279g10bkyd3mf2q/2016-03-31%2006.17.45.jpg?dl=0
I use one of these now and have to say it out performs the original Motorcraft carb by a 100% It is on the stone stock '78 460 in my car hauler. Throttle response is excellent and economy did improve. I sold these when they were new in the '70's at the speed shop I was working at. There was a double pumper version list # 7011 that is far more rare.
gt350hr- Posts : 662
^^^^That's what I was saying GT. there is a DP version List #6709 also, rare as hen's teeth.
» Holley 750 Vacuum Secondary Carb. List 83310
» Holley 600 Cfm List #9834 Vacuum Secondary Carb.
» Holley 650 CFM SpreadBore Vacuum Secondary Carb. List. # 8700
» Holley dp 850 carb
» Edel. RPM intake & 870 Holley carb
