Here is a good read....
ThndrChkn
Here is a good read.... Empty Here is a good read....
Post  Lem Evans December 1st 2009, 11:43 pm
Just one example:
The FRPP aluminum SCJ's will flow about a MAXIMUM of 360 CFM @ about .650" valve lift on the intake side with only a "bowl port" job.
The Trick-Flow streets will flow a MAXIMUM of about 375 CFM @ around .750" valve lift with the same kind of simple "bowl port" job.
There is no contest if the maximum flow numbers are the only criteria.
The SCJ's flow about 315 CFM @ .400" valve lift and those STREET's will flow about 275 CFM @ .400" valve lift.
At overlap the SCJ's intake valves are minimally hampered by a valve notch in the piston where the STREET's intake valves are deep into an intake notch which hampers flow from the intake; until the piston is out of the way.
The SCJ's intakes empty into the cylinder right near the bore centerline where the bore is widest and the STREET's empty near the exhaust side of the bore which is not a prime location. The exhaust valve locations have similar values.
The SCJ's use about 5° less ignition timing than the STREET's in order to make maximum cylinder pressure.
NOW ... the choice between cylinder heads has a whole new meaning than simply maximum flow numbers.
__________________
www.rmcompetition.com
R.M. Competition - All Custom Engine Building of any type at its' Finest...!
Parts and Supplies from just about everybody; whatever's necessary ... 1(586)909-1591
Here is a good read.... Empty Re: Here is a good read....
Post  billandlori December 1st 2009, 11:53 pm
I guess the area under the curve at all cam lift values is most important. The peak flow is nice but one needs to look at the whole picture, not just the peak numbers.
Bill
Post  windsor December 2nd 2009, 4:23 am
Very good read, indeed!
Post  bruno December 2nd 2009, 9:53 am
that right there is what puts flow numbers in perspective ................ Great read Lem Wink
http://WWW.CKRME.COM
Post  ThndrChkn December 2nd 2009, 4:39 pm
Thanks Lem.
Doug... Here is a good read.... Icon_cool
ThndrChkn
ThndrChkn
Post  Lem Evans December 2nd 2009, 5:02 pm
Cool ...Thank Randy he wrote it alien
Post  IDT-572 December 2nd 2009, 8:04 pm
Now do a max effort port on both heads and really see the SCJ's shine. Cool
Post  the Coug December 2nd 2009, 9:50 pm
even with a simple port bowl blend a set of Streets can build 800+ hp. in essence thats still pretty impressive...
Post  Lem Evans December 2nd 2009, 10:01 pm
This thread is about what to think about ....not which is best ....tfs/scj/p51...we are very lucky these days...aint NO wrong cyl. head...just the one that is best for ones needs/budget .
Post  the Coug December 2nd 2009, 10:04 pm
I agree Lem if Fords were like Chevies we would have 27000 different heads to choose from...I am just happy we have the great choice we have....
Post  Diggindeeper December 3rd 2009, 12:45 am
the Coug wrote:I agree Lem if Fords were like Chevies we would have 27000 different heads to choose from...I am just happy we have the great choice we have....
Are Procomps included on this list of great heads??? Very Happy
couldnt resist.
Diggindeeper
Diggindeeper
Post  bbf-falcon December 3rd 2009, 1:04 am
We have come along way w/bbf heads in the last few years,but I think we have a long way to go yet. I think the GM stuff is still ahead of us in R&D and also in selection and low prices. I would like to see more companies step in like DART and Merlin. IDT has some really nice Selections for A head BBF's right now. If I was building a Big inch A head I would seriously look at going w/them. JMO
