9" PG spragless tq converter.
9" PG spragless tq converter.   Empty 9" PG spragless tq converter.
Post  dirt_worker April 12th 2016, 12:14 am
For sale.
This is the tq convertor that I got from Nick Bruno a few yrs ago.(was in his foxbody) I believe he said it was originally built by Camerons Torque covertors. Its a 9" and fits a powerglide. Turbo spline. 6 bolt flange. Anti ballon plate. Went 6000 behind my 557. When I had it out last I had my guy tighten it up some. Should be in the 55-5600 range now.
Never ran since re stalled.  Worked great in my 3800lb truck. It went a 1.41 60' on 275 radials at 3800 lbs.
$550+ship.
9" PG spragless tq converter.   20160411_205500-1_zpsslchizkb
dirt_worker
dirt_worker
9" PG spragless tq converter.   Empty Re: 9" PG spragless tq converter.
Post  mlp911 April 12th 2016, 10:42 pm
did you run a mid motor plate with this and if so, how thick?
mlp911
mlp911
Post  mlp911 April 12th 2016, 10:45 pm
also did you run it na or nitrous?
mlp911
mlp911
Post  dirt_worker April 12th 2016, 11:41 pm
I ran it NA behind a 950hp 557.
Its setup for a 1/4midplate. I ran it w a .125 midplate a and one hardned washer between the convertor and the flexplate.
dirt_worker
dirt_worker
Post  dirt_worker April 19th 2016, 12:48 pm
Make offer!
dirt_worker
dirt_worker
Post  dirt_worker April 26th 2016, 10:44 am
$500+ship
dirt_worker
dirt_worker
Post  87mustang514 August 10th 2016, 10:31 pm
Do u still have the converter for sale
87mustang514
http://Jerrysullivan45@gmail.com
Post  dirt_worker August 11th 2016, 10:19 pm
87mustang514 wrote:Do u still have the converter for sale
Yup...still available
dirt_worker
dirt_worker
9" PG spragless tq converter.   Empty Converter information
Post  87mustang514 September 13th 2016, 10:11 am
Sent a pm yesterday
87mustang514
Post  jbozzelle September 17th 2016, 11:19 am
This is confusing me. Wouldn't it not fit if it was built for a 1/4" midplate and your plate is thinner? The thinner plate leaves less room between the converter and the flexplate?
Curious since I need a converter and I'm running a plate around .110 thick
I'm curious how much less it would stall in a 3,000lbs car? What's the stall of your new converter in your truck now?
Post  dirt_worker September 19th 2016, 11:19 pm
i just know that bruno had an alum midplate and mine is a mild steel from keith fulp. and the bolts had a gap when the convertor was all the way unto the back of the crank. I had to shim it back out to make up the diffrence of the thicker midplate.
idk how it would work in your car. all i changed from when nick ran it was the fin angle. when i first got it it only went 4000 behind my motor since nick had it setup for nitrous.
my new one only goes 4500 on motor and 6000 w. spray.
Id do $525 shipped if anybody wants to try it
dirt_worker
dirt_worker
Post  FalconEh September 20th 2016, 12:00 am
dirt_worker wrote:i just know that bruno had an alum midplate and mine is a mild steel from keith fulp. and the bolts had a gap when the convertor was all the way unto the back of the crank. I had to shim it back out to make up the diffrence of the thicker midplate.
John,
You are correct in your thinking, you are  -.015 your plate is thinner,get the washers included and measure them the plate thickness does not rule your combination out, it just means it is not the same and it worked with XXX nobody will put the final dimension on the line to say it will work but you have to deal with the dimension it worked with, beware of the starter if you add a plate.
Post  dirt_worker September 20th 2016, 1:28 am
SOLD. Payment pending Very Happy
dirt_worker
dirt_worker
Post  87mustang514 September 20th 2016, 6:40 pm
Payment sent , thanks
87mustang514
