The PI's Showed UP Early
gmsmkr
The PI's Showed UP Early Empty The PI's Showed UP Early
Post  supervel45 April 21st 2016, 8:49 pm
Pictured coming soon. All I can saw is WoW. I did not expect this much from the sellers photo's. They have been pretty much fully worked including polished chambers. 550HP Plus here we come.
The PI's Showed UP Early Empty Re: The PI's Showed UP Early
Post  supervel45 April 21st 2016, 9:28 pm
I hope you guys can see these pictures, If not let me know an I will put the links.
The PI's Showed UP Early 2016-04-21%2019.44.49
The PI's Showed UP Early FBmdoUFvkNCKSRGiHYUDuY3eS8zmhVb5qjgBNHhZnEw?size=1024x768&size_mode=3
Post  supervel45 April 21st 2016, 9:33 pm
The PI's Showed UP Early 2016-04-21%2019.44.01
https://www.dropbox.com/s/awjbc485n8ksyv2/2016-04-21%2019.43.21.jpg?dl=0
https://www.dropbox.com/s/z107qzw0t410ljv/2016-04-21%2019.43.14.jpg?dl=0
https://www.dropbox.com/s/5tuagpysue1xtf7/2016-04-21%2019.42.49.jpg?dl=0
https://www.dropbox.com/s/qt0wqe57jlf0086/2016-04-21%2019.42.24.jpg?dl=0
https://www.dropbox.com/s/lxg2l1k4v4jbm07/2016-04-21%2019.41.33.jpg?dl=0
https://www.dropbox.com/s/z4bifccsndctu8g/2016-04-21%2019.41.17.jpg?dl=0
https://www.dropbox.com/s/5t7jlyshjpcz3t7/2016-04-21%2019.41.07.jpg?dl=0
https://www.dropbox.com/s/mg2cuy2pyadp7hb/2016-04-21%2019.40.58.jpg?dl=0
https://www.dropbox.com/s/hbiwqk8smn3ptr4/2016-04-21%2019.40.40.jpg?dl=0
https://www.dropbox.com/s/3o44x77qknxyd58/2016-04-21%2019.40.30.jpg?dl=0
https://www.dropbox.com/s/ajhycnamf8hmjut/2016-04-21%2019.40.24.jpg?dl=0
Post  supervel45 April 21st 2016, 9:38 pm
Post  supervel45 April 21st 2016, 9:39 pm
The PI's Showed UP Early GqxJmA3p4l5mILpi0dk-xAYtnYS86ZlXRd5MRDg07M0?size=1024x768&size_mode=3
Post  supervel45 April 21st 2016, 9:43 pm
The PI's Showed UP Early GIno9tx0MXMKZ7cR_2_m2kDC8KwdcDfO7RzMhl4euYE?size=1024x768&size_mode=3
The PI's Showed UP Early GYUYHCZ_RBan8ai5MxgpbvQINk9LiOcly3lDR_sxC4E?size=1024x768&size_mode=3
The PI's Showed UP Early UbwjXAcIgsL9ey4R7sa2s5Qmagw7v15IlIbI87Xt5ek?size=1024x768&size_mode=3
The PI's Showed UP Early 5ktZ9N8tZ6tYAlabxMvIp7sU9qhht4QQfgXc5IBA-Xg?size=1024x768&size_mode=3
The PI's Showed UP Early YV2YkPyD2hIPItG7Sw1GHi-3kyN9YSpCyPl2YwalK7U?size=1024x768&size_mode=3
Post  supervel45 April 21st 2016, 9:49 pm
The PI's Showed UP Early NBFfcq_TWC2UFfgzidteerF8plZOL0HYFSMVNaBFVBA?size=1024x768&size_mode=3
The PI's Showed UP Early VWX7Odsz0GzHTxBcKQyntsD1MTNc1QTe7SZ2XovL31I?size=1024x768&size_mode=3
The PI's Showed UP Early SdrSUXro1D_5hniUvOXvZAVyr7yLoR_miBYEKw3c-Zs?size=1024x768&size_mode=3
[img]
Post  supervel45 April 21st 2016, 9:53 pm
Trying a different background to get the bowl work to show up. Hope you all can see them. I think my 29 year hunt for these is finally over.
The PI's Showed UP Early FGj9qxgQSwATCjr_xsUMKO_XWafEBOkQu_-A4CNyV9M?size_mode=3&size=1024x768
The PI's Showed UP Early RTMZLixtqmSoEnqCMAfpejXATGi5ZuFZc57m4kTsY8o?size_mode=3&size=1024x768
Well do they look worth a shit Blake/Charlie or just some hogged out junk. I may put them on the flow bench and see soon?
Post  gmsmkr April 21st 2016, 11:12 pm
All I'm getting is little green squares no pics Mad
gmsmkr
gmsmkr
Post  supervel45 April 22nd 2016, 12:00 am
gmsmkr wrote:All I'm getting is little green squares no pics Mad
All I can say is try and click on the links and let me know if they work. I am at my witts end with posting photo's around here. We have tried every different way that we know how and they show up sometimes and sometimes they don't. If we are loading pics on drop box like now they will likely not show up when you click the link so go back and try again or latter.
Post  res0rli9 April 22nd 2016, 12:04 am
post 4 down are Blank on my putor scratch
Post  supervel45 April 22nd 2016, 12:20 am
res0rli9 wrote:post  4 down are Blank on my putor scratch
Can you see any pictures? Dropbox is loading new ones now and is blocking mine also.
The PI's Showed UP Early Empty PC Seals Too
Post  supervel45 April 22nd 2016, 12:25 am
The PI's Showed UP Early KtvfwPxCuJIw4KZcxAGSImek_noBEyEbVXaTLDgBsD8?size_mode=3&size=1024x768
The PI's Showed UP Early PUZU_r-wTxB01RCFzhkFbSZcQGTGZzGUDVFyeFa83_U?size_mode=3&size=1024x768
Post  supervel45 April 22nd 2016, 12:27 am
The PI's Showed UP Early HVnKMrg1B_7l8gdvAM8SpR3LlQ0NxsTCnmV3tuyW5JY?size=1024x768&size_mode=3
Post  jbozzelle April 22nd 2016, 9:08 am
Only photo hosting website I can get to work properly is photobucket.
Post  cool40 April 22nd 2016, 9:18 am
jbozzelle wrote:Only photo hosting website I can get to work properly is photobucket.
x2...the links worked in one post.i hope the pics weren't the new heads,looks like a dropped valve did all the polishing. Laughing
Post  supervel45 April 22nd 2016, 10:19 am
For what I gave for them and what my machinist fixed the last one for, almost just like that, I am well ahead of the game. This is not going on a Pro Stock engine it will be just fine as long as it is not cracked and the guy said he would take them back if they are.
Post  cool40 April 22nd 2016, 1:26 pm
Embarassed from your first post I assumed they were bolt on ready. That shouldn't be a problem to fix anyway,good luck. Cool
Post  supervel45 April 22nd 2016, 1:54 pm
Thank's Cool J.. I talked to my machinist today and he said bring them on. Even if one head was cracked and unusable I am still way ahead of the game for what I have in them. Someone sure spent a ton of hours on these, and the other set like them, the guy wanted $2,200 and he did not have much wiggle room as he had $2,400 sunk into them. Even if I had to start with a bare head I would have 90% of the parts to assemble it and a pattern to copy the port work with. I think I will put them on the flow bench just for kicks to see where they are at.
Post  stanger68 April 22nd 2016, 10:40 pm
I can see all the drop box pics. Nothing else though.
Post  supervel45 April 24th 2016, 1:14 am
The PI's Showed UP Early 2016_04_21_21_05_54
The PI's Showed UP Early 2016_04_21_19_44_49
The PI's Showed UP Early 2016_04_21_19_40_24
The PI's Showed UP Early 2016_04_21_19_42_24
The PI's Showed UP Early 2016_04_21_19_44_01
The PI's Showed UP Early 2016_04_21_19_41_07
The PI's Showed UP Early 2016_04_23_20_10_00
The PI's Showed UP Early 2016_04_18_22_15_59
The PI's Showed UP Early 2016_04_18_22_16_09
The PI's Showed UP Early 2016_04_18_09_47_36
picture upload
Post  supervel45 April 24th 2016, 2:09 am
The PI's Showed UP Early 2016_04_21_19_41_33
The PI's Showed UP Early 2016_04_21_22_31_06
^^^^^^Good Chamber.
The PI's Showed UP Early 2016_04_16_23_36_48
I Hope these pictures came through let me know?
Post  supervel45 April 24th 2016, 3:30 am
The PI's Showed UP Early VNRfZVospb08mbiZeVknfv27X4ybJx6VyM9IkJwRNdE?size=1024x768&size_mode=3
The PI's Showed UP Early SSKFxXA2Xghz0mxY9IprYfISziPDGIFoGKuMc7kRHmc?size=1024x768&size_mode=3
These are The D2VE's I dropped a valve that Harold Sim's repaired for me. Thanks for an excellent job and price. Harold's Automotive and Machine Shop Richmond Tx. Just barely South of Houston by Grand Parkway 99 and 59 South. Good People
