A460 block trick flow heads
BBF552
Darrin Gorham
torino501
A460 block, 18 bolt, new in the crate 4.360 bore. just drooled over and soaked in wd-40 periodically. 2000.00 local pick up or shipped on your dime.
trickflow A460 heads. new in box just drooled on an soaked in wd-40 periodically. 18 bolt, ti retainers, roller springs good for .850, 87cc cnc chambers, fast as cast ports w cnc gasket match.(how they came from T/F) all guides all rockers studs come in the box with them. 2500.00 shipped
jomar stud girdle for heads. new. 225.00 shipped
thought one day I might build something nasty. but I have other irons in the fire. I would never use them to there fullest potential. thanks guys.
located north of Houston.
torino501- Posts : 417
Re: A460 block trick flow heads
pm sent for heads. check your in box.
stanger68- Posts : 500
Pm sent for heads also
John Myrick- BBF CONTRIBUTOR
Part # for heads is TFS-5451T802-M83
Looks to have a 2.350 int valve
Interested
Hard ro say but Going to have to pass. 1- 1/2 raised exhaust port and chsvy flange i would have to rework my whole front end. Damn good deal tho.
interested in it all, how far are you from Houston raceway? I have a friend running there this weekend.
Darrin Gorham- Posts : 180
Do you still have the heads?
BBF552- Posts : 34
I have 2 PM's sent to him about purchasing the heads from yesterday that he hasn't read as of 10 minutes ago
pm'd you john
Money Sent
Nice, I will be looking for a new post in the proven builds section when the parts arrive...
FalconEh- Posts : 1448
FalconEh wrote:Nice, I will be looking for a new post in the proven builds section when the parts arrive...
LOL gonna be a while, need pistons, maybe rods, and fogger system
John Myrick wrote:FalconEh wrote:Nice, I will be looking for a new post in the proven builds section when the parts arrive...
john I have a nice set of eagle h beams and A460 dome pistons id let go for real cheap $300
they 4.5 bore , kinda odd combo that requires a 4.25 stroke crank.
just throwin it out there.
bbfstanger- Posts : 223
bbfstanger wrote:john I have a nice set of eagle h beams and A460 dome pistons id let go for real cheap $300
Thanks, but I already have eagle rods and I'm either going to 598 or 632. If I decide to get a Callie's crank I might as well get the 4.75" arm and sell my 557 rotating assembly
shipped thanks john..
Okay, great thanks 8.50 here we come
John Myrick wrote:Okay, great thanks 8.50 here we come
I dont think you'll need a fogger to go 8.50's with that.
Dave De- Posts : 797
I'm not running super high compression and my car is 3600 lbsDave De wrote:John Myrick wrote:Okay, great thanks 8.50 here we come
Sweet. That's where I want to be.
70FB- BBF CONTRIBUTOR
^^^^^^X2 but you will want to go 7's after so add the fogger or two
block still available.
FalconEh wrote:Dave De wrote:John Myrick wrote:Okay, great thanks 8.50 here we come
Nope, 8.5 is all I have. I would have to cut the cage out and put moly in and that's not in the cards.
» A-460 parts etc...
» Trick Flow A460 heads
» A460 heads and trick flow intake
» Trick Flow A460 Intake
» A460 Trick Flow Intake
