Stock valve covers
Prlanger
Stock valve covers
Hi guys,
I am building a 520 stroker with P51 heads for my BB CJ 71 mustang.
Does anyone know what the highest lift cam I can use with stock CJ valve covers?
Intending to use a roller cam.
Cheers
Peter
Cheers
Peter
Prlanger- Posts : 4
Re: Stock valve covers
http://www.dscmotorsport.com/asp/Products/popup_PartDetails.asp?PartID=951
If I am not mistaking I think Price Motorsports make them also.
supervel45- Posts : 4499
PS: I like CJ valve covers a lot also but, I would not base my cam choice on them.
I am glad you asked that question. I just found something new. I am also planing CJ valve covers an maybe roller rockers also.
http://www.medicemfg.com/products_get.php?c=Valve%20Cover%20Spacers%20-%20Ford
Wow. Ok problem solved....
Prlanger- Posts : 4
Give Keith Fulp at KFM Motorsport a shout.I'd bet he can make you a set.
Sorry,bout double posted..
Prlanger wrote:Hi guys,
Cheers
Peter
The O.E.M. valve covers with the "oil dippers" won't even go onto the P-51 heads without removing those dippers.
I'm using the stock cj covers on a .666 lift solid roller, (Iron CJ heads). just removed the oiling dipper/tabs inside.
ROAD RAGE- Posts : 229
I used stock valve covers with a .660 lift solid roller. Rockers tapped the cover so I just ran two valve cover gaskets to gain enough clearance.
SLord82- Posts : 145
» Stock valve covers w/ spacers
» valve cover studs for aluminum valve covers
» 429/460 Valve covers
» 429 460 M/T valve covers
