what cam to use
Rev4Q
what cam to use
Hello everybody, putting together a 532 for a Eliminator 21' sport cruiser with a Berkeley jet. I have a Dove-a block at .080 eagle h beam rods [6.80] and crank [4.3] Probe dished pistons, can go to flat tops for desired compression if needed. Have a set of D2OE PI heads that will get port matching and bowl work with ferrea valves 2.25/1.76. I can run tunnel ram with 660s or a single carb. Would like to get 600hp/600tq with a max of 56/5800 rpm.Would like to stay with a hydraulic unit, is this feasible? if so what would be cam of choice to achieve this output? Thanks,Eric
Rev4Q- Posts : 6
Re: what cam to use
Rev4Q wrote:Hello everybody, putting together a 532 for a Eliminator 21' sport cruiser with a Berkeley jet. I have a Dove-a block at .080 eagle h beam rods [6.80] and crank [4.3] Probe dished pistons, can go to flat tops for desired compression if needed. Have a set of D2OE PI heads that will get port matching and bowl work with ferrea valves 2.25/1.76. I can run tunnel ram with 660s or a single carb. Would like to get 600hp/600tq with a max of 56/5800 rpm.Would like to stay with a hydraulic unit, is this feasible? if so what would be cam of choice to achieve this output? Thanks,Eric
Forget the tunnel ram and use a port matched "Track Heat" street TFS manifold..
Get a "custom" camshaft.
Re: what cam to use
Ok, who would be the best for me to contact on a custom grind?
Rev4Q- Posts : 6
Re: what cam to use
Rev4Q wrote:Ok, who would be the best for me to contact on a custom grind?
There are many ... I will let someone else answer that because I am kinda prejudice.
Re: what cam to use
The cam i have for it is a nos C-460 ford racing
Rev4Q- Posts : 6
Re: what cam to use
rmcomprandy wrote:Rev4Q wrote:Ok, who would be the best for me to contact on a custom grind?
Randy can make you a custom cam or Lem
Re: what cam to use
69F100 wrote:rmcomprandy wrote:Rev4Q wrote:Ok, who would be the best for me to contact on a custom grind?
^^^^^^^ rmcompetition is Randy his contact info is in his signature.
FalconEh- Posts : 1448
Re: what cam to use
Rev4Q wrote: The cam i have for it is a nos C-460 ford racing
The C460 will work OK at Wide Open Throttle but, not so good anywhere else.
Re: what cam to use
http://www.ebay.com/itm/222104658703?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
You might want to pick this up and another like it. They where the 660's big brother and should work well on a big cubic inch healthy Big Block as they where intended for. Very rare carb. and the add is kind of misleading with the L-88 bit, but, they probably misinterpitted the old Holley catalog.
supervel45- Posts : 4499
Re: what cam to use
OEM heads if ported and I/E ratio is maintained the exhaust need a lot of time (duration) to get the exhaust out. These heads need big duration split cams.
Straubtech- Posts : 293
