Safe amount to cut spring seat depth on SCJ heads
Safe amount to cut spring seat depth on SCJ heads Empty Safe amount to cut spring seat depth on SCJ heads
Post  frank13 May 11th 2016, 5:40 am
As the title states, looking for what is safe to take off of SCJ heads.
Want to be at 1.95- and after rechecking the maching shop I am:
cylinder intake exhaust
1 1.870 1.916
2 1.900 1.918
3 1.88 1.921
4 1.85 1.920
5 1.876 1.911
6 1.87 1.910
7 1.90 1.916
8 1.897 1.914
Id like to take .080 off- doable?
frank13 is online now Add to frank13's Reputation Report Post
frank13
frank13
http://www.frankskinkracing.com
Safe amount to cut spring seat depth on SCJ heads Empty Re: Safe amount to cut spring seat depth on SCJ heads
Post  dfree383 May 11th 2016, 7:15 am
Have you looked at +.050 locks and different retainers?
And a better more consistent valve job ?
Post  68galaxie May 11th 2016, 9:32 am
I would not cut the spring seat depth.
First fix the valve job, and then change retainers or locks or both as needed.
+0.100" retainers and possibly + 0.050" locks if needed.
Cheers
68galaxie
68galaxie
Post  rmcomprandy May 11th 2016, 10:15 am
I have gone .030" and also then used a .030" thick spring locater to get an extra .060" but, I have no idea how far is to far.
Post  frank13 May 11th 2016, 9:57 pm
Well went to the machine shop. After some talk about options I went with
Comp valve job
New longer intake valves
Everything installed at 1.95
Was all cleaned chased and built.
Ready to bolt on
frank13
frank13
Post  frank13 May 12th 2016, 10:37 pm
frank13
frank13
Post  frank13 May 12th 2016, 10:41 pm
shop had them done same day, and I picked them up in the am:
  So I went to the machine shop with a fix in mind and after some talk and some thinking I decided to bit the bullet for new intake valves, fresh competition valve job and make sure the heads were flat and straight.
Well heads were off 11 thousandths which of course they fixed and the heads came out great.
So here are some pics of the heads fresh from the shop:
Checking the installed heights
Safe amount to cut spring seat depth on SCJ heads IMG_20160508_173313_zps785prbwe
Checking the installed height still
Safe amount to cut spring seat depth on SCJ heads IMG_20160508_1938200_rewind_zpsjvuzjrll
Fresh heads:
Safe amount to cut spring seat depth on SCJ heads Imagejpeg_0_6_zpshykp9c9l
Safe amount to cut spring seat depth on SCJ heads Imagejpeg_1_zpsxz2a7xqd
Safe amount to cut spring seat depth on SCJ heads Imagejpeg_2_zpsk4ujzfgz
Nice and pretty!
frank13
frank13
